Old hot rod way to lower a 40-48 chevy car
Discussion in 'The Hokey Ass Message Board' started by 48 stylemaster, Aug 25, 2013.
  1. 48 stylemaster
    48 stylemaster
    from Canada
    What would of been the way old hot rodders would use to lower an early chevy car 40-48. Before all the mustang 2 kits and swapping it out for the later 49 and newer styles. I am wanting to do it as if it was being done in the early 50's so using the 50's suspension would of been too expensive. Would they just heat the coils with a torch to lower it? I am aware of using the airplane style shocks instead of the stock shocks, but any other info would greatly be appreciated
  2. Mr48chev
    lowering blocks in the back and heating or cutting the coils in front but heated coils keep sagging until they finally are laying on each other if they don't (and they usually do) break first. The 51 Merc I bought when I was 16 (50 years ago) had heated coils and years later when I subframed it (the frame had been damaged in a wreck) both coils were broken when I pulled the front end out from under it.
    I'd pull them out, take a cut off wheel and cut the number of coils of that I thought would get it where I wanted it and put it back together. I'd probably cut one coil at a time to make sure I didn't drop it too much, more work but less "oh ****" factor in the long run.
  3. Roger O'Dell
    Roger O'Dell
    Heated springs, stepping "A" arms, My 49 merc spindels flipped upside down
  4. rusty1
    rusty1
    ...remove bottom spring plate off of front A-frame, space it down with inch or two heavy tubing, bolt back together.
  5. mashed
    mashed
    from 4077th
  6. motoandy
    motoandy
    from MB, SC
    I was told beer placed in the truck. Could raise it up as the night went on.
    IDOXLR8MY48 likes this.
  7. 48 stylemaster
    48 stylemaster
    from Canada
    Good pointers everyone. I wonder if I can flip the spindles on the 48. Going to take a look at that tomorrow.
  8. I had the coils heated on a 47 Plymouth back in the 60s. After that it rode like the
    proverbial lumber wagon. Would have been much better with cut coils. As was said
    above, only cut one coil off at a time because that can produce a greater amount of
    drop than you think. You can even go 1 1/2 coils instead of two if necessary.
    Good ole lowering blocks for the rear should be OK.
  9. Rusty O'Toole
    Rusty O'Toole
    Newer spindle supports (up to 1954) will lower it a couple of inches, 15" wheels off a 49 or newer Chev, instead of the original 16s will help. These are stock parts and will not louse up the ride.
    Then there are cut coils, lowered spring plates etc as already discussed.
  10. 48 stylemaster
    48 stylemaster
    from Canada
    It's looking like I might be able to flip my spindles which will drop the front about an inch. Now just have to try and get those king pins out and give it a try
  11. Rusty O'Toole
    Rusty O'Toole
    Newer spindle supports will drop it 2". I wouldn't bother turning them over for only 1".
  12. 48 stylemaster
    48 stylemaster
    from Canada
    Alright thanks Rusty. Will the original spindles bolt up to them or will I have to use the newer spindles as well?
  13. Some homework for you: http://www.cbforum.net/forum/index.php?topic=29931.0
    "Kool rides" in Kansas has a bolt-in front lowering kit which drops the front 2".
    You have to remove the rivets which hold the bottom "A" arm to the spring plate.
    Sounds like a good option, uses your original springs. I have to have a look at how it would work (tie rod clearance, etc) but in theory it seems OK.
  14. sololobo
    sololobo
    Ha Ha, this is a reminder when all our cars rode like the proverbial "lumber wagon". Rear end bangin and front clangin. Good ol days? Thank god for all the new stuff! ~sololobo~
  15. When I was a kid in the '50's, we didn't have any money so did things the hard way. I shared a '47 Chevy with my mom . I wanted to lower the front end so I just pulled the springs out. Looked cool. Mom didn't realize the logistics of no suspension and hit a dip in the road at speed. That was the end of my modifying the car.
  16. 48 stylemaster
    48 stylemaster
    from Canada
    Thanks Kant spell I think this is the route I am going to go seems simple enough to make
  17. 47Feetlinesedan
    47Feetlinesedan
    from Corydon In
    I have been told that the closed drive shaft will want to raise the motor. Is that correct?
  18. oldwagonlover
    oldwagonlover
    Do you have any pics of these? I would like to make a set for myself.
    Thanks.
  19. Rusty O'Toole
    Rusty O'Toole
    I think the old spindles will fit on the newer spindle supports. If I found one in a junk yard I think I would get everything from the control arms out and use the newer brakes if they were bigger.
    The problem with reversing the spindle supports or flipping them over, is the king pin angle. Your wheels will be all ****eyed unless you heat and bend the support to reverse the angle. They used to do this but today it is easier to buy dropped spindle supports. In the case of your Chev you don't even have to go aftermarket, the factory made dropped spindle supports.
