Are the 35/36 Ford pickup radiator lower mount holes, wider than a 32 radiator?...
Discussion in 'The Hokey Ass Message Board' started by F&J, Aug 25, 2013.
  1. F&J
    F&J
    EDIT: I have changed the ***le to 35-36 instead of the 33/34, as Dave gave the measurement on the 33/34, which is still too narrow.
    I have an old channeled car that is missing the radiator and shell.
    There are 2 custom radiator mount brakets welded/moulded to the front frame with one hole per side, and each hole is more towards the rear, like a 32 radiator I tried.
    The 32 radiator is made with those holes towards the rear, rather than centered with the core.
    But the 32 radiator is roughly 2" too narrow. One side fits the offset bracket hole perfectly.
    So, I never owned a 33/34 pickup radiator, but I thought they are wider?
    (those 33/34 truck radiators/shells were used on hot rods around the Northeast, so I am just guessing right now).
    Thanks in advance
  2. F&J
    F&J
    does anyone have a 33/34 truck radiator or ch***is to measure between the 2 boltholes? :)
  3. fisherboys
    fisherboys
    yes I can just as soon as I get off work about 3:30 here in ohio
  4. Dave Mc
    Dave Mc
    1934 = Nineteen and 3/8 ths Inches
  5. F&J
    F&J
    Thanks for the measurement, Dave. That is still about 2" too narrow for these mounts.
    Car was built in the Boston area, and some old survivors there, have the oval 38-39 Ford truck grill, but I thought those frames are the same through 40, and a 40 radiator is 2" too wide.
    So, my last guess is 35-36 Ford truck? I have seen a couple of old rods with those shells.
    The original builders son is still looking for some missing pics that were taken at an Autorama back then; I guess I can hope that he can find them.
    EDIT: I just changed the thread ***le to read 35/36...
