1932 ford a body on 1930 frame
Discussion in 'The Hokey Ass Message Board' started by PAT454SS, Aug 26, 2013.
  1. PAT454SS
    PAT454SS
    The ***le says it all. I scored a nice 1930 frame and plan to put a 1932 5 window fibregl*** body on it. I saw the opposite many times but a 32 on a 30 frame looks pretty odd, but anybody tried it yet?
    Gimme your impressions!
  2. Dirty Dug
    Dirty Dug
    That's a really bad idea, really bad!
  3. HOTRODPRIMER
    HOTRODPRIMER
    Looks like ****,,I'm just being honest!
    The wheel base on a Model A is roughly 103" and Deuce frame is 106". HRP
    BTW, a introduction is advised. HRP
  4. You gotta be kidding us!!! REALLY?:confused:
  5. hotroddon
    hotroddon
    Channel that fibergl*** body down low and no one will know!
  6. finn
    finn
    My uncles did that in the late 30's-early 40's---32 Ford roadster on a Model A frame and drivetrain.
    They were farm boys, not hotrodders I guess.
    Later s****ped the whole car.
    So much for inheriting a Duece.
  7. Deuced Up!
    Deuced Up!
    You know maybe if you look around you could fine a nice VW pan and running gear to set the body on! ......
  8. pasadenahotrod
    pasadenahotrod
    from Texas
    My brother's 32 5W spent its racing life on a Model A frame with various engines.
    After he bought it I found him a 32 frame. That is what it sits on now never having turned a wheel under power since he bought it 20 years ago.
    That said, a channeled gl*** body on an A frame wouldn't be the end of the world. If you can't see it it don't matter.
  9. PAT454SS
    PAT454SS
    Ok guys, i'm new to those cars, a bit dreamer but have the skills on mechnaics and bodywork but don't want to spend 100k on a car you know. I had the frame for next to nothing.
    Do you have a better project to suggest? Don't be too bad on me!lol:D
  10. modelacitizen
    modelacitizen
    You'd be better off selling the model a frame and using whatever money you got towards a set of repro 32 rails. 700$ and worth every penny for a 32 ford. Keep in mind, that putting a little extra cash in to a deuce can go a long way.... it's not the right car to cut corners on. should you ever decide to sell it, you'll get the money back.
  11. ^^What he said^^
  12. I would advise against it for every reason modela citizen said.
    If you were hell bent on doing it, here's a few things you would need to do.
    Stretch the A frame 3"
    Box it for sure.
    Make it wider or install model a sub rails in your Tupperware II floor pan.
    Make a nice c notch /z in the rear.
    That's just getting started and well over the cost of some 32 rails.
  13. That's kind of like putting a 302 Ford Motor in a nice Camaro body. Yes it can be done but you'll never live it down. People will point out how wrong it is forever. Kind of takes the fun out of things. Yes I did that in 1971.
    The Wizzard
  14. APACHE FS
    APACHE FS
    Search the A on 32 rails, then do the math. You'll see why it's not reversed.
  15. dan31
    dan31
    In the end it will be more work,more money,you wont like it and you wont get anything for it.
  16. Chris
    Chris
    Do it! Dare to be different
  17. finn
    finn
    I sort of like the idea of a 289 in a Camaro
    Atwater Mike likes this.
  18. Ford Mike
    Ford Mike
    How about a flathead?
    I say go for it! If no one ever tried anything new we wouldn't be building hot rods in the first place, we'd all be restoring old cars. Do a mock up and post up a pic.
  19. Don's Hot Rods
    Don's Hot Rods
    from florida
    What the guys are trying to tell you is that it will be a real mismatch. There is a reason people put the 32 frame under the model a and not vice versa. The A frame is shorter and not dimensionally as wide, not to mention not as strong. It will look lost under a deuce body.
    Do it right, save up for a 32 frame, even a repop.
    Don
  20. gasheat
    gasheat
    from Dallas
    Sometimes its better to be a spectator than a participant.
  21. hallrods
    hallrods
    A friend of mine had a 1932 ford 3window gl*** car on a model a frame with a 392 hemi in it. He was from the Chicago area and moved to Two Rivers Wi in the early 90's the car was channeled and it looked good maybe it was stretched I don't remember I'll see if I can scan and post a picture of it.
  22. hallrods
    hallrods
    Took a picture of a picture
  23. HOTRODPRIMER
    HOTRODPRIMER
    Looks odd to me. HRP
    And a Deuce on 32 rails..
  24. 2racer
    2racer
    they also sell gl*** model a bodies....
  25. F&J
    F&J
    It looks ok to me. Maybe take the other opinions if it was a choice original body. With the gl*** body, and A frame, channel it stretch it, whatever...and make a hot rod.
    who says your first build needs to be your best effort with the best parts?
  26. hallrods
    hallrods
    It does look a little odd but if you want the channeled look I think you could make copy of the front of the 32 frame and build your own.
  27. Krash
    Krash
    from Cleveland
    If it were me I'd find a way to get a '32 frame. However, there is nothing wrong with using what you have. Go for what you want!
  28. fortynut
    fortynut
    I kept reading, thinking maybe this was one of those weird ones that keep popping up like mushrooms around a barn. Just because you have a frame from one car and a body from another, and want to put them together does not always equal wonderful. The reason there are traditions is that some combinations turn out better than others; and those that follow along this same path improve but don't neglect to understand the reasoning that these elements worked. These folks who are telling you to go ahead should be ashamed of themselves. It may be possible, but after you spend your time and money to do it, those who know better will laugh at you. Honest. Sell one, or the other, or find a way to get Deuce rails, or sell the Deuce body and go all 'A'. You'll be happy you found the patience to wait until you got all your ducks in a row. It may take longer to build but you can drive something closer to perfect without ever looking back.
  29. lakeroadster
    lakeroadster
    from *
    It's a gl*** body...
    Stretching a Model A frame is about as easy as it gets...​
    Have at it and have fun. No harm, No foul.​
  30. Don't listen to all the nay- sayers.do what you want and if you like it run it if not change it.its your car
