Projects 59 chevy wagon in progress
Discussion in 'The Hokey Ass Message Board' started by Cody Walls, Mar 23, 2010.
  1. 6t5frlane
    6t5frlane
    from New York
    Great thread. One of the best builds in a long time...Kudo's young man
  2. one2roc
    one2roc
    Ditto..... What the bug box said :D Just can't seem to get enough of this fantastic build up!
  3. NoSurf
    NoSurf
    Absolutely Amazing.
    Thank you so much for taking the time to take pics and post them for us all to see.
  4. one2roc
    one2roc
    Hey Cody,
    I probably should go back and look but did you end up making your own gl*** channel for the rear window yet? I know it's posted on another thread but I don't recall seeing you make another piece yet. I have the same issue on my 62 wagon. Haven't looked around but ***ume I'll have to have it made as well. Keep up the great work!
    Allan
  5. Wowcars
    Wowcars
    9 days without an update. You're killing us man...
  6. Cody Walls
    Cody Walls
    just a quick Monday up date , sorry guys things have been crazy non stop again and ill get back to you all when I can , with the horn ring I feel like im missing something that is keeping it from staying stationary
    <TABLE cellPadding=6 width=600><TBODY><TR><TD align=center>[​IMG]</TD></TR></TBODY></TABLE>
    on another note ive been priming and doing a lot of final block sanding on the last bit of parts I have , all the parts that are going dark green are ready to be sprayed , im still working on the light green parts (the hood front lower valance and that kinda stuff , the hood has been ****ing up a lot of time especially the under side .
    even customizing the license plate , when all said and done and I grind the welds , there will be no visable bolts holding the plate on .
  7. oldman2
    oldman2
    All the bits and pieces take so much time, but it's looking good. Wish I could help with the horn ring, but don't have a clue....Jim
  8. one2roc
    one2roc
    It can be tough juggling all the day to day tasks and keep the details of ones own project in check. There's only so many hours in a day and let's not forget family..... You're on the path to success Cody, keep up the great work!
  9. Cody Walls
    Cody Walls
    another Monday update ,ON SCHEDULE this time !!!!!!!!!!!!!!!!!
    also finished up my custom no bolt holes license plate
    just some wire lacing
  10. 40StudeDude
    40StudeDude
    I hope by now you've figured out there more then a couple of items you're missing in the horn ring...the internal turn signal switch, horn ****on, turn signal canceler and a couple of other parts...IF that is a Chevelle wheel (and it looks like it to me), check out Eckler's for those parts...or Cl***ic Industries...they should have what you need...
    R-
  11. Cody Walls
    Cody Walls
    yes I was very impressed with dennis work , thanks for the kind words
    thanks jim ,
    nope not yet just been too busy
    thank you
    sorry just been to busy ,
    thank you
    very cool , yes he seemed like an awesome preson an we just chatted on the phone
    thank you
    thank you for taking the time and checking it out
    nope not yet just too busy with everything else , but I plan on making it
    I know I know
    yes they do ,
    exactly , it just seems like the days are running together
  12. Cody Walls
    Cody Walls
    thanks for looking that up , I actually have that piece , what I need to know is what keep the horn ring stationary
  13. Cody Walls
    Cody Walls
    its a 64 Pontiac grand prix wheel, its totally different , I have everything I need except on part that keep the horn ring stationary
  14. Cshabang
    Cshabang
    hey buddy! cant wait to see it done!!! I gotta get a closer look at how you did the "wire tying" love the plate idea btw
  15. Cody Walls
    Cody Walls
    you and me both , with the wire , its called wire lacing , it was done quite a bit back in the day , I found out how to do it on line . once you get the hang of it it goes pretty quick ,
  16. Cshabang
    Cshabang
    so did you lay out the spacing when you did the lacing?....haha
  17. Cody Walls
    Cody Walls
    na I just eyeballed it
  18. Cshabang
    Cshabang
    sure you did...you have worse OCD then I do....haha
  19. drdave
    drdave
    Cody, on the horn ring, I'm thinking there is a a spring loaded lock ring in the middle that twist locks onto the steering wheel. It has been YEARS since I've looked at the back one (my 64 currently has a not stock wheel on it). Unfortunately, my stock wheel is in storage 30 miles away and I can't get to it at the moment. Be several weeks at least. As soon as I can, I will go retrieve it and take pictures of all of it so you can see what bits you are missing.
  20. oldman2
    oldman2
    Cody, everything looking great...Jim
  21. Buzznut
    Buzznut
    Cody, I'm amazed at your ability to polish just about anything.
    Maybe you could give me some feedback on something. I don't want to hijack this thread so I'll message you with my question.
  22. Cody Walls
    Cody Walls
    Haha , I actually did
  23. Cody Walls
    Cody Walls
    Monday picture update time
  24. Cody Walls
    Cody Walls
  25. oldman2
    oldman2
    Details in building a car are what makes them special, and you keep nailing it each time...Jim
  26. rattlesnakehoey
    rattlesnakehoey
    from Australia
    Unfreakin' believable. Keep it coming. Thumbs up from Down Under.
  27. Bruce A Lyke
    Bruce A Lyke
    Keep it up, it is really coming together and will be winning awards in no time.
  28. pwschuh
    pwschuh
    Cody, I've always wondered what happens when you tighten nuts and bolts down over a painted surface? Are you just letting what happens happen, or are you taking some precautions to preserve your beautifully prepared parts?
  29. one2roc
    one2roc
    This is better than reality television, I can't wait till the next installment! Keep up the great work Cody........
  30. Cody Walls
    Cody Walls
    just a quick out of the blue picture update
