235 flat cam symptoms
Discussion in 'The Hokey Ass Message Board' started by joethehuman, Aug 26, 2013.
  1. joethehuman
    joethehuman
    Here's the story- my 235 has started to idle rough, one cylinder not firing very well, esp. at low rpms. Checked spark plugs, adjusted valves statically, replaced plug wires. This was rebuilt w/ stock spec. cam about 15000 miles ago. I didn't know enough o add zinc the first 8000 miles or so. So what are the chances the cam has lost a lob? this has electronic non-vacuum distributor and a newer 2 barrel.
  2. SMOG_GUY
    SMOG_GUY
    from Dinuba
    A vacuum gauge is handy for this. Try it one at a time on two full vacuum ports (sometimes you have to to see the problem).
    You're looking for high, steady vacuum. 17" hg or higher. More importantly, does the needle flick? A slowly roving needle 17-19 is fine. I'm talking about a quick needle action.
    Time to get a vacuum gauge.
  3. R Pope
    R Pope
    Pull the cover and watch the valves. If one isn't moving as much as the rest it will be easy to spot.
  4. JohnEvans
    JohnEvans
    from Phoenix AZ
    No more spring pressure than those engines have flat cam in not very likely. Pull the cover any flat lobe will have a bunch of valve clearance.
  5. Rickybop
    Rickybop
    You must not've liked my answer on your earlier thread?
    http://www.jalopyjournal.com/forum/showthread.php?t=827633
    I still think it might be a vacuum leak at the base of the carb. Did you check like I suggested? If it was a flat lobe, it would probably be sneezing out the carburetor.
    Joe, and in case you don't know...you don't have to start a fresh thread. Just bump the old one by posting on it.
  6. joethehuman
    joethehuman
    My carb is a holley weber Pretty new I'll check for vacuum leaks. And I have a vacuum gauge installed,Runs off the intake manifold. Tomorrow I'll pull off the valve cover and check the action while it's running.
  7. SMOG_GUY
    SMOG_GUY
    from Dinuba
    So is the vacuum high and steady, then?
  8. Rickybop
    Rickybop
    Ohhhhhhhh...ok. Holley Weber carb...not a Rochester.
    Of course, disregard everything I said except maybe the possible vacuum leak.
    Sounds like you know that though. Good luck.
  9. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Of all the early Chevy sixes I've ever torn down (a lot), I've seen one that had worn cam lobes, and the whole engine looked like it had never had an oil change. Like someone else said, it's a three minute job to remove the valve cover and watch the rocker arms.
  10. joethehuman
    joethehuman
    The vacuum is bouncing between 15 and 20 at idle and is bouncy all thru the rpms. The rocker arms all look to be moving about the same amount. So I'm thinking the cams fine. Couldn't find any vacuum leaks around the intake and carb. base. No vacuum advance or wipers. I've got NGK plugs, with the little skinny electrodes, gapped to spec. What I'm I missing?
  11. SMOG_GUY
    SMOG_GUY
    from Dinuba
    Vacuum is bouncing? It should be high and steady.
    Sounds like a valvetrain problem.
  12. 40FordGuy
    40FordGuy
    Ditto, what SmogGuy said.
    4TTRUK
  13. joethehuman
    joethehuman
    OK, but everything looks good with cam, everything's working good with the rocker arms, push rods, valve springs. Where should I be looking?
  14. sunbeam
    sunbeam
    Leaky valve check compression.
  15. joethehuman
    joethehuman
    Well, compression check showed 100- 125 on #'s 123 & 6. Only 30- 35 on 5 & 6. Could it be the head gasket is leaking between the 2 low cylinders? Or burnt valves on both cylinders.
  16. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Either or, but if I had to bet money on it, I'd say that when you remove the head, you'll find a head gasket with a chunk missing.
  17. joethehuman
    joethehuman
    That's what I found. A piece blown out between the 4th and 5th cylinders.
  18. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Well, at least that's an easy fix.
