here are a few updates of my original comp. coupe anglia bodied dragster. its the top photo in black primer. body being fitted too my modified ch***is research k-88 ch***is.mike
Cool build Mike , are you going to do a build thread on it? What power plant and trans are you going to use, Tim Jones
once i get closer to finishing it up i'll go back and do an build up date. i'll be running an early 394 olds mtr. with hilborn fuel injection.. power glide trans olds rear hopefully run around 7.50s-- 8.00s 140 mph more on this build at a later time thanks mike
finally finished up on the body and tin work. firewall is in and i'm working on installing the 3 windows. 2 rear ones will remain open. painted it a light blue like a/b speed car ( i'm trying to follow his style. I should be putting the body on the ch***is next week. and try getting it to a locale show at ( BIG ALS TOYBOX ) Its our dover reunion gathering. Big Als is located in Conn. Here are a few pics.
