Projects Track-Rod 34 Coupe Build - NZ style
Discussion in 'The Hokey Ass Message Board' started by slick377, Jan 23, 2013.
  1. Restore it
    23 vote(s)
    29.1%
  2. tidy it up
    47 vote(s)
    59.5%
  3. leave it alone
    9 vote(s)
    11.4%
  1. bt34
    bt34
    Yo, that ol' piece o junk is finally starting to shape up...keep the pics coming.
  2. Looking great, as other posters have mentioned... dig the dirt track influence.
    In your first two posts on this thread there's a couple of shots of a '35/'36 Coupe in the background... any info on that ? In the early '90s I had a fenderless & channeled '35 Coupe to which was an old Chch rod from the '60s. Last we know of it went south and has disappeared now for many years. The styling is very similar, although it's in the dark/background, just a long shot...
  3. n.z.rodder
    n.z.rodder
    Are you still after the tea strainers? Have you tried Tulmac in Levin? Contact Greame Tulloch (06) 368 2202. They're carby spe******ts so they might have something to suit.
    Scotty
  4. slick377
    slick377
    That pic was at Rusty Acres in Nelson, don't know if Steve has still got it or not, last time we connected - 12 months or so ago, he was selling up a whole lot of stuff though...;)
  5. slick377
    slick377
    thanks for that Scotty, I'll give them a whirl
  6. slick377
    slick377
    damn right Hairy, "wait till I get this ****er rollin" they'll be hangin on for mercy
  7. slick377
    slick377
    Been toiling away getting the trans all trued up ready to mount, ran into a little snag - the ****tershield clocked up within tolerance east/west but 30 odd thou out the other way - solution - make a pair of offset dowels and correct it... man is it good having a lathe handy, there are so many times you just need a little spacer or want to flush off a cut. Had to scoot down the road and pick through a fellow petrol heads ******y bin to find a suitable piece of hard steel - pin from a digger bucket - that'll do it! All sorted and sits perfect, well - within 0.0025" anyway, which is within spec. Now I've found another small hurdle - the Quartermaster release bearing doesn't fit with a twin plate clutch - shiiiiit! ah well "problems are only solutions waiting to be found" some wise **** cracks as he finishes your last beer and disappears into the sunset with no idea or solution.... while I ponder a solution I'm going to ***emble the front end......
  8. slick377
    slick377
    Got a bit more done, found a solution to the throw out bearing - Howe part # 82870 is the magic fix, and I found one in a speed shop within a days frieght. So now I have the gearbox all mounted up, driveshaft in place - which was ordered a year ago with measurements from a mock up. A good feeling when something actually fits perfect from your theoretical measurement from the past... In the pics you can see the torque arm which is correct length for the cars wheelbase and wieght distribution and can be altered to suit track conditions, also see the "J Bar" for diff location which can also be adjusted to control side bite or rear roll centre.
  9. Avgas
    Avgas
    Looks perdy kool for a Kiwi build!, look forward to seeing it, good luck with the build, Wayne
  10. slick377
    slick377
    Thanks Dude, I'll take that as a compliment coming from you... I've seen your car around - in the magazines that is, looks good too!
  11. slick377
    slick377
    Started to ***emble front end, got axle soft mounted in the vice, put bat wings in place, heaved on the 15/16" spanner to wind up the tapers to hold those things in place and PING! the perch nut flies one way the washer another and I'm thinking W T F is goin on here... well after I pick up the peices it becomes evident some body further back in history for some reason WELDED studs to the perches???? Man am I glad it happened in the shop, check this out
  12. Great build, I'll be following you on it!
  13. slick377
    slick377
    While the body is off the ch***is there are a few jobs that will be easier to do now rather than later. Like set the pedals in the right static position, attach return springs, and make adjustable pedal stops. Results show below...
  14. Roadsir
    Roadsir
    Great build, I really like the QC and race-inspired stuff...Great Job!
  15. ss34coupe
    ss34coupe
    Awesome work being done here!
  16. slick377
    slick377
    Started on the fuel tank retaining straps, today - the draught has broken meaning the water tank is being filled and hoprfully the earth is being rehydrated, it also means garage time! I install waterproofing membranes so rainy days can be a blessing when youv'e got a car waiting for you in the workshop.
  17. slick377
    slick377
    Finished fabricating the fuel tank straps, lots of marking & drilling to get the race car look - and make them lighter... the straps are made from 1" x 1/8" corten steel with 1/2" lightening holes at 1" centres.
  18. That's one seriously cool hot rod coupe you are building there! Can't wait to see it done!
  19. Candy-Man
    Candy-Man
    Very tidy build, nice strong frame !
    Just being curious, will you bend up a nice shifter arm to located the shifter closer to the driver ????
    Keep that perch pin, for a nice piece of wall art, of what could have occurred ! :)
  20. slick377
    slick377
    AAWWwwwww! thanks guys for the kind words, sometimes when you have a vision it does'nt matter what others say - but having positive energy flow your way certainly feeds the p***ion...
    Regarding the shifter - good spotting, mocked up the seats the other night and looks like it's gonna be reeeel close, I've got a long handled Hurst chrome stick out of a truck shifter kit, with a little "tweak" as you enquired, it will be sweet as. ;)
  21. Rem
    Rem
    That's a tough-looking Coupe. I think it deserves paint - tidy it up and run it for a season to work out any bugs, but then finish it up nice.
  22. slick377
    slick377
    Right on the money REM, the plan is to "break it in", go hard for a season then tear down and ***emble it up niiiice - but I promise you this - it will never be a trailer queen
  23. craig mcneill
    craig mcneill
    I like your brake pedal set up, Im doing the same kind of thing
  24. slick377
    slick377
    Made a rear bumper nerf bar, finished bottom fuel tank mounts, put the last of the threaded sleeves through the ch***is rails...
  25. slick377
    slick377
    Made up some frame horns to replace the ones g***ed off in a previous life
  26. slick377
    slick377
    Front bumper and nerf
  27. slick377
    slick377
    mocked up side nerf
  28. GaryB
    GaryB
    from Reno,nv
    cool looking build,good luck with it
  29. gnichols
    gnichols
    from Tampa, FL
    I like it! Digging all the oval track stuff! Gary
  30. slick377
    slick377
    Made a modification to the steering - I needed to slow down the 8:1 ratio of the steering box, so I've fitted a Howe 2:1 reducer out of a dirt late model. Pic's below show new mount to locate box from rotating under load.
