Features Doing Falcons Right
Discussion in 'The Hokey Ass Message Board' started by falconizer_62, Jul 23, 2008.
  1. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Well, that's that.
    Universally despised.
    I guess I'll look elsewhere for a stock appearing gl*** hood.
  2. Bigcheese327
    Bigcheese327
    U.S. Body Source has a stock-appearing 'gl*** hood for the '62 and '63 cars. I haven't dealt with them, though, so I have no way of knowing if they're of good quality or from a company with good service.
  3. hotroddon
    hotroddon
    I have used them - but for Mustang parts - not my Anglia (it is a steel body with a gl*** front end that was made from a mold off of my car in 1968)
    The parts from Unlimited were "OK" quality, a little m***aging and I might use that same hood on my 63
  4. Jeem
    Jeem
    Alliance Vendor
    EvilFalcon1961...just so neat!
  5. falconizer_62
    falconizer_62
    The radiator came, so I got going installing that. I gotta find out where all of that sits before I can finish the front sheet metal.
    It is so fun to be back working on it again. The bumper is at the chrome shop getting stripped, the boomerang is getting rechromed, and I think I will start on the fan shroud tomorrow :)
    I am trying to stay busy getting small things on it done instead of waiting around and losing momentum.
  6. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Lookin' good Falconizer...
    A dude I know that drives a wrecker called ta' say he'd seen a 63 Futura 4 door with a ***le for $400 in a storage yard a few miles from where I live.
    I took a ride over this mornin' for a look-see:
    I p***ed on it....although I did score all four of the hubcaps for $20.00.
  7. falconizer_62
    falconizer_62
    Was it that rough? You don't usually find these around that cheap any more
  8. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    When I opened the left rear door to look inside, it fell out of the body.
    That was enough for me.
    Are the pictures showin' up?
  9. falconizer_62
    falconizer_62
    Yep, I can see the pictures just fine
  10. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Well, if I had your metal working skills, I prolly would've scooped it up. ;)
    I'm just a broken down old line monkey.
  11. BurntOut , how far away from you is the salvage yard, and are you able to buy other parts off that 4 door ? How much Beer money do I need to give you?..... :D
  12. falconizer_62
    falconizer_62
    Thank you for your kind words. Things always tend to look better in pictures. You can start dreaming and your dreams are not immediately dashed by foul smells, rust flakes , and overall pain in the *** factor. "That's no big deal", I say to myself when the reality I am confronted with does not line up with my dreams. That is one of the reasons the wagon is such a big project. If I would have had something running and driving, I would have left it pretty much alone.
  13. [​IMG]
    YESSSSSSSSSSSSSSSSSS............................................
    EvilFalcon1961: That car is soooo bad***. Now I'm searching Craigslist for an early Falcon. Damn you!
  14. ^^^^^^ haha! they're infectious little sods arn't they :D
  15. 1971BB427
    1971BB427
    from Oregon
    Looks like some decent parts left, but I'd have also p***ed at $400. They're still not too spendy around my area, and I hate fixing rust!
  16. falconizer_62
    falconizer_62
    Trying to make some headway on the radiator. I think this should work...
    So many small variables to consider if you do not want anything rubbing holes through the tubes on the core or rattling while running. I am also careful knowing that I could come up with a better way to do it after I'm halfway through this attempt.
  17. falconizer_62
    falconizer_62
    DOH!!! Down to the emergency bandaids.
  18. gimpyshotrods
    gimpyshotrods
    Those are my favorites!
  19. hotroddon
    hotroddon
    just posted a steering column conversion kit in the cl***ifieds if anyone needs such parts.
  20. need louvers ?
    need louvers ?
    Hello Kitty is soooooo stylish...
  21. falconizer_62
    falconizer_62
  22. falconizer_62
    falconizer_62
    Man, worked all day on this darn radiator and still don't have much to show for it. The fans are so close to the pulleys that it's tricky to make this thing serviceable, and not go all tube ch***is on the front. It felt like one step forward, two steps back all day. But here's what I got :
    I think I would like to mount the lower channel with rubber cones so that the radiator can tilt backwards to release the upper Channel from the body.
    The lower channel is larger than the upper Channel so the shroud fits on the inside on the bottom and on the outside on top. That hopefully will allow me to slide the fans and shroud out the top in case I have to change a belt, and allow me enough room to tilt the radiator back to release the upper channel for removal. There's a million ways to do it, I'm kind of stuck as to which is best. The fruits of the day...
  23. rcrown
    rcrown
    Figure ill jump on the band wagon and post a few photos of my 1962 Falcon project.
  24. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
  25. rcrown
    rcrown
    Thanks, that was right after we brought her home and unloaded off the trailer.
  26. rcrown
    rcrown
    Have not decided which route i am going with on wheels, still debating the options. This photo was still the factory 4 lug
    -Ron
  27. Bigcheese327
    Bigcheese327
    Great '62 (my favorite roundbody). Do you have the original trim? Those washboards are killer.
  28. falconizer_62
    falconizer_62
    62s rock. Deluxe trim package and the best tail lights ever! What brand front tnd kit is on that?
  29. Bigcheese327
    Bigcheese327
    Hell yes. They're so great somebody even grafted them into my '61 Futura!
    I couldn't believe it when somebody suggested swapping them for '63s.
  30. falconizer_62
    falconizer_62
    Boooooo!
