10 inch clutch fouling
Discussion in 'The Hokey Ass Message Board' started by fatboy tim, Sep 1, 2013.
  1. fatboy tim
    fatboy tim
    from Edinburgh
    Men
    New rebuilt flathead with 32 3 speed and replacement 10 inch clutch.
    Problem is that new clutch slightly different from old one so ends of fingers fouling transmission housing.
    I think I can spacer around 1/8 th between transmission and bell housing anyone done that?
    Thanks for helping.
    Dave
  2. wbrw32
    wbrw32
    It sounds as tho you have the wrong pressure plate..you need one with the shorter fingers for the 1 3/8-10 throw-out brg.The one you have is more than likely for use with 1"-10 TO brg
  3. fatboy tim
    fatboy tim
    from Edinburgh
  4. 40FordGuy
    40FordGuy
  5. JohnEvans
    JohnEvans
    from Phoenix AZ
    If the fingers are fouling the TO bearing nose you have the wrong PP. If ,however the weights on the outer end of the fingers are hitting the trans case you have 2 choices 1 grind the weights off or 2 get a PP that does not have the weights. Your post is not clear exactly what your prob is to me.
