is there a better 'bolt on" carb for a 235?
Discussion in 'The Hokey Ass Message Board' started by worthop, Aug 29, 2013.
  1. jkski
    jkski
    carter YF
  2. Fatkid138
    Fatkid138
    ImageUploadedByH.A.M.B.1378063994.478247.jpg ImageUploadedByH.A.M.B.1378064018.566942.jpg ImageUploadedByH.A.M.B.1378064034.950160.jpg
    Carter yf's
    Meanwhile at the Hall of Doom!
  3. worthop
    worthop
    I am looking for a single carb to replace the stock one
  4. Fatkid138
    Fatkid138
    Carter yf is a direct bolt on for single also. As long as you get the right one for the application.
  5. Fatkid138
    Fatkid138
    Carter yf 2100s is manual choke for 1954 chevy 235
    Carter yf 2101s is auto choke for 1954 chevy 235. Sometimes they append a letter after the s for example 2101sa. That is the same carb but different production runs. It might have different jet size or such. But still a bolt on.
  6. plym_46
    plym_46
    from central NY
    Another thing to consider is airflow through those after market 4 inch air filters. They **** at ****ing. At minimum double them up, but better still fabricate something to use a real filter element. Even a couple sauce pan lids with a 6 inch round will flow much better that those Mr. Gasket elements. If anybody has a flow bench that could check this out I bet you would be surprised on how restrictive those are.
  7. check out my set up for sale . just saying .
  8. samurai mike
    samurai mike
    just a quick note, the 32/36 weber is the carb that we use on the 1300 cc suzuki samurai engine. maybe if you used two of them?
  9. worthop
    worthop
    Thanks Everybody.....Fatkid; I think I will be looking for one of those 2 Carter YF numbers...Thanks
