adapt a caddy 500 to a standard trans?
Discussion in 'The Hokey Ass Message Board' started by twenty gallons, Sep 2, 2013.
  1. twenty gallons
    twenty gallons
    Does anyone know of an adapter that will mate a standard stick shift trans to a 500/425 Cadillac engine?
    I want to try something... but I cannot find an adapter to get away from the Auto trans.
  2. spiderdeville
    spiderdeville
    from BOGOTA,NJ
  3. randydupree
    randydupree
    from archer fl
    all you need is a pontiac standard bell housing and a flywheel from an after market supplier.
    I think McLoud or Mc somebody makes the flywheel.
    Then you have to drill the crank for the pilot bushing,
  4. Hnstray
    Hnstray
    from Quincy, IL
    You don't need an "adapter"....you need a Buick, Olds or Pontiac manual shift bell housing......so-called BOP......that block pattern is the same as the Caddy.
    The flywheel may be the more difficult to source......not sure if there is a factory GM
    flywheel that fits, though aftermarket types are available.
  5. Swifster
    Swifster
  6. spiderdeville
    spiderdeville
    from BOGOTA,NJ
  7. twenty gallons
    twenty gallons
    thanks Guys, That is what I needed
  8. falconsprint63
    falconsprint63
    from Mayberry
