Features Doing Falcons Right
Discussion in 'The Hokey Ass Message Board' started by falconizer_62, Jul 23, 2008.
  1. Evilfalcon1961
    Evilfalcon1961
    from Ma
  2. Evilfalcon1961
    Evilfalcon1961
    from Ma
  3. rcrown
    rcrown
    I do have the original trim pieces in the trunk of the car. Not in the best shape but may be able to savage them.
  4. jdownunder
    jdownunder
    your car is close to a 1960 australian falcon.i just cut the roof off one today to graft on to a better body.collecting parts to build an americian falcon TWO door.the back pillar on that 62 is so george ****ing jetson i love it
  5. Bigcheese327
    Bigcheese327
    My trim is also imperfect. Rather than worry about repairing and replacing it, I'm going to have the paint match the trim instead (I.e. flat or semigloss).
  6. Question for Evil , What size are the wheels on yours? I'm looking at a set of 15x7s for the '60 . I realize yours are bigger but not sure how much bigger !
  7. Evilfalcon1961
    Evilfalcon1961
    from Ma
    they are 16x7 4" backspace or 0 offset
  8. fca2572
    fca2572
    from Texas
    Here is a black plate 63 Sprint I just got in from California. I think it is going to make a nice car. I really like the factory clock
  9. That looks like a really clean/honest old car ! What are your plans for it ?
  10. Thanks Evil , based on how smart yours look I went and bought these today , They're 15x7 with just over 4" back space so if my measurements are correct they'll fit in the rear nice and tidy .
    We have a set of early 5 spokes in 14x7 that I had planned to use but the back space on them is only 3 1/8" so they're too tight in the rear fenders .
  11. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    It worked!
  12. Evilfalcon1961
    Evilfalcon1961
    from Ma
    those should look great ! only reason went 16" with this brand the 15's had more of a curved spoke not straight up and down. let me see some pictures asap when you mount them @! best of luck
  13. rcrown
    rcrown
    Does anyone know what size bearing OD the lower steering shaft needs on a 62? I know the inner is 3/4" for the DD shaft. What can i use instead of ordering a custom made piece. Any help would be appreciated
  14. Alfster
    Alfster
    You needed that weird width 8 inch we put in the convert...
  15. Haha, yeah that would've worked. I know where your Hideout is too...
  16. 1971BB427
    1971BB427
    from Oregon
    I bought flanged bearings at my local hardware store to fit the end of the column on my Austin project. Just used dial calipers to measure the shaft and housing, and found a flange bearing that slid inside and fit. The one I found fit the column housing pefect, but too large internally for the metric column. I made up a bushing from some s**** tubing, and tacked it to the shaft to take up the slop, and it fits perfect now.
  17. gimpyshotrods
    gimpyshotrods
    Did you find a set of pictures, or see them in-person in 15" and 16"? I am thinking of going with 15's, for a little more sidewall, for our crazy roads, but I am interested in seeing the curved spoke. All I am finding is the same "typical" photo.
    Edit: never mind. I put on my bi-focals. I see it now.
  18. :D
    Wanted to post a thank you here for Jims Cl***ics .
    Jim had seen me asking for back up lamps and the gas cap retainer for our '60 .
    He chased up another Hamb'r for some back up lamps for me , and then he said send me your address I have a gas cap retainer you can have. I sent our address to him , he refused to let me pay for the retainer , posted it off and it arrived safely today . I'm stoked!
    I should also be thanking the rest of you lot here as well :)
    The help and answers to questions while I piece this little jigsaw puzzle back together have been great.
    I fitted up the Shelby 4 pot brakes on the front of the car today and discovered that the 14" wheels ( just rollers ) don't clear the calipers so I'm feeling decidedly clever for buying the 15" Mini-lites that are on the way now .
  19. Alfster
    Alfster
    And you now HAVE to sell the 14 wheels as Michelle said you can't keep them for any more projects as there are NO MORE PROJECTS until you finish the ones you already have..... [​IMG]
  20. I like your " Sensible Hat" !
  21. tpw35
    tpw35
    Almost finished with mine, working on drivability now.
  22. falconizer_62
    falconizer_62
    Very nice tpw35! I love how falcons can be done in so many styles and look great in all of them.
  23. falconizer_62
    falconizer_62
    Well, the radiator mount is getting closer to being finished. At least I know what I am supposed to do from here on out which certainly helps.
    I was able to use the original sheet metal on the top of the radiator support and just a box it all in, and now it is plenty strong. As far forward as the radiator needed to sit, the cap was right in the middle so I had to go around it
  24. falconizer_62
    falconizer_62
    Now, I have to box the end sections were the crossbar attaches. I will plate it outside and tie it into the corner and box it on the inside.
    I got the outside of the right hand side finished.
    Before, and after.
  25. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
  26. Made some more progress today ...
    Head lining fitted , front and rear screens fitted , ****oned up the last of the wiring , fitted driveshaft and E brake cables , adjusted rears and am ready to bleed brakes tomorrow. Battery is on charge now....
  27. Alfster
    Alfster
    Looks good but, I don't think the fenderless style quite suits that model. Ha ha ha
  28. dirttoo
    dirttoo
    I kind of like mine with the fenders off.
  29. falconizer_62
    falconizer_62
    Wow 4t6ford! That is quite an extensive list of stuff you completed. Was the headliner install tricky?
  30. Alfster
    Alfster
