57 Chevy Apache or Cameo?
Discussion in 'The Hokey Ass Message Board' started by JonnieG, Sep 3, 2013.
  1. JonnieG
    JonnieG
    I'm just getting into car collecting, after growing up with a 72 Ford F100 Custom with 460/4-barrel carb. Still miss it.
    So I have an opportunity to buy a 57 Chevy pickup for $6,000, but I need to understand if what I'm being told is legit.
    Seller says it's "Registered as 57, fender emblems say 3100 apache." But after researching on collectors forums, it doesn't look like the Apache model came out until 58.
    Can anyone shed some light on this?
    Thanks so much!
  2. TULSA
    TULSA
    from Tulsa
    Your going to need to post a picture.
  3. blyndgesser
    blyndgesser
    from Georgia
    1958 was the first year for the quad headlights, IIRC.
  4. JonnieG
    JonnieG
    Here's a photo. Chopped 4" off the cab (which I believe is a bad thing). But like I said, seller says it's registered as a '57, but has 3100 Apache on the fenders.
  5. JonnieG
    JonnieG
    And thanks so much for the quick replies!
  6. Bullet Nose
    Bullet Nose
    I don't think I've ever seen a chopped long bed 4WD pickup before.
  7. Steel 35
    Steel 35
    There is no part of a cameo there. The hood may be 57 from the primered raised hood ribs?
  8. SRMN8R
    SRMN8R
    from Central VA
    The Apache moniker was not used until the 58 model year, unless I'm mistaken (again).
    That looks like it's a 3/4 or 1 ton truck - not the 3100 which was a 1/2 ton short bed. If the bed is 89", it's a long bed half ton. If the bed measures 97", it's a 3/4 or 1 ton.
    Regardless, I'm betting someone switched emblems, or fenders, or a bunch of stuff. Don't have my VIN codes here at the office, but you should be able to check them out pretty easily if you can get the info off the seller.
    - J
  9. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Does it really matter at this point, considering how the truck was modified? But, the 55(2nd series), 56, and the 57 Chevy trucks were known as Task Force trucks. The Apache came along in 58 with the quad lights.
  10. belair
    belair
    Woah-looks like a 57 from what little I can see of the front end, but it could be a 58 or 59 with a 57 front clip. ItT is also, IMO, ugly. Save the 6k for something else.
  11. JonnieG
    JonnieG
    You guys are great. Yes, it's been significantly modified to more of a hot rod. My son thought it was the coolest thing he's seen (15 year old musician), so I thought I could take it on as a project for the two of us. But I like the idea of saving the money on something I can get a return on later, if we ever decide to sell it.
    Here's the rest of the description:
    rebuilt 454 with aftermarket chip, cam, intake, headers, dual flomasters
    CUSTOM GAUGES
    CUSTOM UPHOLSTERY
    CAB HAS 4 INCH CHOP
    4L60E AUTO Trans with overdrive, and independent front suspension
    4X4, 3/4 TON 8 ft bed
    New ball joints, fresh brakes, KYB monomax shocks, New alternator, starter, radiator, plugs, wires, and lifters
  12. 55 dude
    55 dude
    Junk for that kind of money, their are lots of those trucks around for way less. I wouldn't even make a offer on it.
  13. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Yeah, for 6large, I'd look for something better.....and certainly something more suited to this forum.
  14. JonnieG
    JonnieG
    Nice to know. Thanks so much for saving me the time, money and effort.
  15. JonnieG
    JonnieG
    Yeah, I'm new to this, so I wanted to reach out. Thanks again.
  16. redo32
    redo32
    Shall we presume the cab was set on a newer frame? If your son wants a 4X4 and can afford the gas, go for it.
  17. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Yeah man, no sweat. Check out the Cl***ified section here....lots of great projects available.
  18. Harrison
    Harrison
    Run. The other way. Fast as you can.
    That truck is uglier than a man's ***.
    JH
  19. classic gary
    classic gary
    what does the VIN on the "A" pilar say? And I'm gonna guess there isn't one because of the chop, and the VIN on the frame is gone because of the IFS, so there is no VIN there either, so good luck with whatever it is.........
  20. JonnieG
    JonnieG
    Will do! Thanks!
  21. mammyjammer
    mammyjammer
    from Area 51
    Flat Black, red wheels and white walls....it SCREAMS Trad Hot Rod!!!
    Seriously, IF it is a factory 4X4 it may be worth a second look. $6K is still high, but if it could had for less.....
  22. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Sounds (and looks) like a $6,000 pile of problems to sort out. Want a modified mid '50s Chevy truck? Buy a stock one and modify it the way YOU want it to be.
  23. 1959apache
    1959apache
    Yeah, that is a long bed step side (less desirable). This project truck should be going for around $2,000-$4,000 depending on where you are in the US regardless of the "mods" or upgrades when the exterior looks like that (probably hiding a lot of bondo). looks thrown together and/or someone ran out of money... either way it looks like shortcuts probably were made.
    Don't even bother looking at that anymore, 55 dude and the others are right.
    I agree with the rest of the guys here: for $6,000 you can find a hell of a nice truck on the HAMB and for the most part people here are honest in their listings since we are all car guys. Even if 6k is over your price range the listings on here are generally more ball park to what they are actually worth..
  24. jhaas63
    jhaas63
    That trucks looms like a real pile man.
  25. 40Standard
    40Standard
    from Indy
    I'd p*** on that SOB. For 6 grand, you can get a lot nicer truck
  26. JonnieG
    JonnieG
    Just talked to seller to let him know I wouldn't pay what he was asking. He said he'd consider any offer, so I told him I couldn't pay any more than $3K, and that I'd still have to see it and a vin. He said he'd take $3,500, and gave me the vin. A57O122322. Sure enough, 57 Chevy 1500 Series ***embled in Oakland, as far as I can tell.
    So, like some of you said, the body was thrown/pieced together.
  27. TULSA
    TULSA
    from Tulsa
    I wouldnt touch the 57 for $1500, thats just me.
    The 67 is off topic here, but could be a good start
  28. cryobug
    cryobug
    I wouldn't buy anything that is in primer unless it is gutted where you can see from the inside of the truck and see that filler isn't hiding holes or m***ive damage. The bed on the truck would be anyone's guess
  29. blowby
    blowby
    from Nicasio Ca
    Yeah, could be a problem off roading...
  30. gimpyshotrods
    gimpyshotrods
    And this truck is too new for this forum.:eek:
