Frame ID
Discussion in 'The Hokey Ass Message Board' started by pancoast, Sep 3, 2013.
  1. pancoast
    pancoast
    from med hat
    Forgive my total cluelessness. I've been searching my local cl***ifieds lately for a hot rod project. I come from a bike building background but am I total newb with cars. I did a google image search and searched around on here but couldn't figure it out. The ad just says 1930's car frame. Anyone got any idea what it is? If it's useable the price is right.
  2. alchemy
    alchemy
    Sure it's usable. For what?
    Hang around here long enough and you will be amazed at what guys can do. But can you do it too? Gotta be realistic.
  3. pancoast
    pancoast
    from med hat
    I was more hoping someone could tell me what it was from originally.
  4. Feo
    Feo
    Not sure... cut it up and use it.
  5. wahoo
    wahoo
    The front looks Chevy to me.
  6. Chevy or Dodge. Without seeing the rear or the axle it is a little hard to tell. But both GM and Dodge use parallel leaf setups.
  7. Kinky6
    Kinky6
    The front cross member doesn't look like the one on my '29 Chevy. Can you get some more photos, and maybe some measurements of the leaf spring length, and center-to-center of the front axle spring pads?
    There is a link to a straight axle website around here somewhere that would help to match some of this info if you could post it on here. Most cars from the '20's to the late '30's, and trucks well into the '50's used dual front leafs like that, so it could be just about anything.
    Later, *****6 :cool:
  8. partsdawg
    partsdawg
    from Minnesota
    REO used them as well,I think.
  9. Xtrom
    Xtrom
    from Forman, ND
    International used parallel leaf springs too. Mine all have Ross steering boxes which are clearly marked. I can't tell what that box is from the picture.
  10. tb33anda3rd
    tb33anda3rd
    need better pictures! keep doing the research, i think that frame might be for a "big" car. it looks like it has fancy shackles, a set up for the big tube bumpers and with the crossmember over the front axle i would bet the radiator/grill shell sat even with the axle.
  11. Most mid 1920s stuff that starts as unidentifyable usually ends up to be Dodge,:D :confused:
  12. Mr48chev
    That could be Dodge from the late 20's too as those were pretty rugged frames for the time. I had on that I tried to use on one of my early attempts at a roadster.
    This is the late 20's Chevy frame that I have for a project that someone hacked the rear crossmember out of before I got it.
    Almost everything except Ford had parallel leaf springs in that time period so it could be from one of several hundred different cars.
    More photos with good shots of how both front and rear springs mount, the crossmembers and the front axle and rear axle if it has one might jar someone's memory of what it started out as.
  13. pancoast
    pancoast
    from med hat
    This might help. Posting from my phone and it will only let me attach one pic at a time. If this doesn't jar someone's memory I can post more.
  14. 31Dodger
    31Dodger
    How about a closeup of the front spring mount on the front spring?
  15. If the price is right grab it!
    You can surely make it work.
    What kind of body are you thinking about???
  16. pancoast
    pancoast
    from med hat
    This is the only other pic I have. He's only asking $150 for all of it so I'm really not out much if I do pick it up.
  17. Atwater Mike
    Atwater Mike
    Looks close in size to Chevy frame, but rear kickup looks more like Es***. (trim about 12"-16" off the rear, and you've got the Bill Niekamp rails.)
    Nevertheless, Model A front crossmember, tube rear/transverse springs would get you 'on the ground' with adjustable wheelbase. (moving rear where you need it, within 'reasonable parameters')
    Es*** rails: (small Hudson, they were popular for the kickup, rail cross section, and front 'sweep'. Very adaptable for hot rods/race cars)
    I've used Es***, Plymouth, Chevy, Model A, and '32, (naturally)
    But when doing up a frame, it first comes all apart. Then the crossmembers, mounts, etc.; AFTER the planning of engine/trans and body placements.
    So...The more desireable the frame shape, the less 'slicing' to make it right!
    This one looks excellent! For the asking price, it looks superlative!
  18. weps
    weps
    from auburn,IN
    Rear spring hanger is not an Es***.
    Too tiny to be an Auburn (plus no X member)
  19. jaxx
    jaxx
    after looking at the picture of the back half of the frame and comparing it to the frame on the 1925 underslung dodge - it looks to be a 25 dodge - you can check out pics of the underslung 25 dodge on the net - ja**
  20. SMOG_GUY
    SMOG_GUY
    from Dinuba
    I've got 30s IHC, Dodge truck, Chevy truck, here right now, it's not one of those.
    Certainly no newer than that...
  21. Bring it home and look for numbers on it.
