Let's say i bought a stock Model A...Are any of the parts worth anything?
Discussion in 'The Hokey Ass Message Board' started by BiscayneBrain, Sep 2, 2013.
  1. Fenders
    Fenders
    On the rod in my avatar I sold the running rolling ch***is for $3K.
  2. Swifster
    Swifster
    The serial numbers are on the engine block and the frame. There is no serial number on the body!!!
    Everyone *****es about VIN problems with the DMV and then sell of the serial numbers that prove ownership. Say I buy Tweeds rolling ch***is and a body from Brookville Roadster. Who's ***le trumps who? Want to bet it's the guy with the frame?
    People worry about buying 'real steal'. They forget about the rest of the car.
  3. 1931modela
    1931modela
    from montana
    minus body should go for $1000-$1500. maybe more
  4. Boones
    Boones
    from Kent, Wa
    if you can find a nice stock A painted in a color you like (and do not plan to chop it), it is cheaper to buy a stocker and take it apart to build a hotrod. trying buying a body, then having the body and paint done. it is more expensive than buying a complete car plus it comes with a ***le (especially if you build a fendered car).
  5. rg171352
    rg171352
    from New York
    So true.
  6. racemad55
    racemad55
    What body style we talking about?
  7. 4BangerDean
    4BangerDean
    I not quite sure what it's called. I know it's a 1930 5 window coupe with a rumble seat. I want to remove the rumble seat and make it a trunk.
    I guess I just jumped in feet first. I decided I wanted to build a hot rod and I'm doing it. I looked at model a's within driving distance and bought the best one in my price range. This build is going to be low budget. I pick the car up Saturday and will post pictures after I clean it up a bit.
    Dean
  8. 5window
    5window
    First, barring a few one-off's, all Model A coupes were 5 window. Second, while you can convert a ruble to a trunk (Mac's a**** others sell the parts) it's not quite as easy as you'd think. Plus a rumble seat coupe will bring more than the same, identical condition trunk equipped coupe.
    Sounds like you're going to take a pretty nice A and make it into a low budget (hoping i don't have to say r_t) rod despite everyone's advice. I think this is where I wish you luck on move on. Good luck.
  9. Texas Webb
    Texas Webb
    And you should know that frame and engine are your serial/vin # to
    that car.Do you get a ***le?
  10. racer32
    racer32
    I pulled the rumble seat back and bottom from my coupe today. It looks to me that at one time it had a trunk. Either that, or the inside panel of the trunk/rumble lid was drilled for either one. Also appears to have a place for trunk hinges. To me, a trunk would be more useful than a rumble that nobody would be able to ride in.
  11. 4BangerDean
    4BangerDean
    Its nice, but not that nice.
    It won't be a rat rod, my 71 year old father wouldn't go for that. His first car was '29 and he knows a thing or two.
    Dean
  12. 4BangerDean
    4BangerDean
    The car has a ***le and it will be transferred and licensed immediately.
  13. 4BangerDean
    4BangerDean
    Here she is...
  14. What number on the ***le did you check the vehicle against? There is a number on the engine block but some DMV's will want to see the number on the frame (which means lifting the body). Sometimes the DMV has added a number plate to the door jam. Please tell me you found the number somewhere on the vehicle.
    Charlie Stephens
  15. Driveway builder
    Driveway builder
    Bro, none of my business... but even I wouldn't rip that thing apart. I'll take a saw to just about anything. You should look into just keeping it a "banger" with a duel carb setup or something. Buy a body, and a frame and build a hotrod... that's all your going to use anyway.
  16. EZFEED
    EZFEED
    Dude thats too nice of an A to rod. Sell it and buy a body only. Seriousley that'd be messed up if you do this. Every old car is a piece of history. When it's too far gone to restore THEN rod it out.
  17. EZFEED
    EZFEED
  18. WhiteZombie
    WhiteZombie
    from Denton TX
    There are plenty of restored Model A's. Cut it up.
    tb33anda3rd likes this.
  19. gimpyshotrods
    gimpyshotrods
    Museums are full. Cut it.
  20. Buy it, rod it, sell the parts on here or Craigs list. There's a hell of a bunch of stock model A's out there for sale if anybody wants one. Restorations, for the most part are boring and ya can't or don't want to drive the snot out of them. Just sayin'.
  21. 4BangerDean
    4BangerDean
    This is not a pristine restored car. It is in good condition relative to its age. The car has been sitting in a barn and the custom velour interior smells like it. Notice the color difference of the hood and wheels compared to the body. The body paint is newer complete with runs. It might be 20+ years old. This was the best one I could find within driving distance and met my budget. This will be my first build and what I think is reasonable for my skill level. I also have the 84 year old farmers blessing. No one else wanted it. I'm happy to own it.
  22. BangerMatt
    BangerMatt
    Depends on condition, I've seen worn out junk go for a grand. If it's all rebuilt (brakes, trans, rear, engine, steering, etc.) it could easily go for $4000 if not more. Good runner should go for $2k-3k
    If you were closer, I'd look to get the trans and rear.
  23. teddyt
    teddyt
    from U.S.
    I did the same thing a year ago. I bought a complete Model A Coupe and only kept the body. The complete running gear was sold as a whole and was an easy sell.
    So,..... what was the end result of keeping just the body?? Other than the usual patch panels,.......I feel very lucky to have this beautiful body sitting in my garage. Some of these cars you see built are in such bad shape that they are literally brought back from the dead. If you want to put those kind of hours in a body because you feel that you saved another one from becoming a street rod, that's fine. But,.....keep in mind that there will be literally countless guys waiting in line that will be waiting to step up,.....take your place,.....separate and put that beautiful gem of a body in their garage,......and sleep peaceful at night knowing what they have. At the end of the day,......you didn't save that car from becoming a street rod,.....you only missed the opportunity yourself.:)
  24. 4BangerDean
    4BangerDean
    I would have bought a nicer one if I had the budget. This one is a good start and some filler has been detected. Who knows what's under the paint. Body work is last in line, though it might see a chop!
  25. whtbaron
    whtbaron
    from manitoba
    Sweet car... if it runs and you were closer, I'd give you a grand for the leftover parts in a heartbeat.
  26. 4BangerDean
    4BangerDean
    I'm sure you would. It's going to take a little more than that.:D
  27. 4BangerDean
    4BangerDean
    Just an update. I ended up selling the Coupe this spring.
    I'll be introducing the new A after I pick it up.
  28. simplestone
    simplestone
    Haha, sweet - here we go again. I can't wait to see it!
  29. 4BangerDean
    4BangerDean
    It's supposed to be here tomorrow morning!
