54 Chevy be lair 235 valve ad.
Discussion in 'The Hokey Ass Message Board' started by five4cruiser, Sep 3, 2013.
  1. five4cruiser
    five4cruiser
    What is the proper way to adj. Valve clearance on 235 hydraulic lifters? Rebuilt engine stock.
  2. five4cruiser
    five4cruiser
    1954 Chevy be lair 2 door post.
  3. waldo53
    waldo53
    from ID
    I hate to ask - but first, are you sure they are hydraulic? Look at the stamped number on the pad just aft of the distributor, if that number ends with ....54 Y then you're good to go. Any other number/letter combo that doesn't end in Y - they are solid lifters.
    The shop manual describes a cold setting procedure that is quite involved, but here's the way I do mine:
    Warm the engine completely. Take off the valve cover. (at this point I install an old cover that I cut the top off of, but this isn't really required as these engines don't throw a lot of oil) With the engine running, one at a time, loosen the lock nut and loosen the adjuster until a click is heard, then slowly begin to tighten the adjuster until the click just goes away, then tighten an additional 3/4 turn. Tighten the lock nut. Repeat for all lifters.
  4. five4cruiser
    five4cruiser
    Yes the engine was rebuilt and my dad had a new can and hydraulic lifters put in.
  5. five4cruiser
    five4cruiser
    Thank you sir.
