Need few tips on clamping up exhaust tubing perfectly to weld
Discussion in 'The Hokey Ass Message Board' started by 55Thunderboy, Sep 8, 2013.
  1. 55Thunderboy
    55Thunderboy
    from NYC
    Im trying to make a custom sidepipe stainless exhaust and im having a tough time just tacking things up right. My car is on stands and the pipe is just too heavy for me to handle with one hand and tack with the mig.
    I want to clamp the sections together somehow but my visegrip clamps arent working well.
    Im using a chop saw so my cuts are perfectly staight
    What can you guys suggest i try to get the pipes to but up perfectly with no gaps? Pipes are 3 inch stainless
  2. Dak Rat
    Dak Rat
    from NoDak
    Well, what I did was take a hose clamp and grind a small slot in the side. I then used the clamp to hold the two pieces together and tack welded the seam thru the small slot I made in the clamp. Move the clamp around and tack a couple places. Remove the clamp and finish weld. Worked for me.
  3. 55Thunderboy
    55Thunderboy
    from NYC
    That is a good idea how wide of a worm drive clamp did you end up using?
  4. fastcar1953
    fastcar1953
    exhaust clamps like these with a slot cut to weld.
    fauj, Engine man and Tim like this.
  5. bandit14569
    bandit14569
    A piece of 2" angle iron 1ft. long makes a perfect pipe brace for straight pieces. Just lay the 2 **** ends together in the angle channel. This also works nice with 2 flat legs welded to angle iron to keep by drill press to hold pipe or bar stock to be drilled.
  6. B Ramsey
    B Ramsey
    Angle iron and hose clamps.
  7. call a freind to help...thats what its all about!!!
  8. mattrod68
    mattrod68
    this is one of the best tech tips i learned when i was younger.
    matt
  9. jaw22w
    jaw22w
    from Indiana
    I use a pair of C-grips with a short piece of 1"x 1" angle iron welded to each grip.
    Works great!
  10. scott mckelvey
    scott mckelvey
    from Towson, MD
    Where space is an issue or tight bends, like the hose clamp method, although little stubby pieces of angle can sometimes do the trick.
    Angle iron is perfect for straight runs, as said. That said I like to use those quick adjust clamps to clamp the angle iron for ease and speed.
    Ill add that I've tried the sleeves sold by ******. Nice concept but they don't work that well, Not worth the money and make for a much junkier weld especially with tigging. So, not worth it. A nice tight fit with little or no gap is the key in my opinion.
    And that said, ill add my 2 cents (which is all its worth), not sure what your plans are but if you went to the trouble of investing in stainless, its well worth time and money to tig them with stainless rod. Little or no blending, no chance of a bunch of wire sticking inside pipe, and no rust to worry about.
  11. 55Thunderboy
    55Thunderboy
    from NYC
    With the angle iron jig are you guys clamping using the standard welding vise grip clamps or something else?
    Im gonna hit the home depot tomorrow after work to grab some angle stock.
  12. SimonSez
    SimonSez
    It might not work on pipe that big, but I have used masking tape when building a 2 inch system and headers.
    Wrap the tape around the joint as tight as you can and then cut out a small section and tack it, then repeat around the other side. Once you get two or three tacks on, remove the tape and finish weld.
    The tape gets a bit charred, but it worked well for me when joining curved sections that are hard to clamp otherwise.
    pat59 likes this.
  13. I have welded miles of handrail together using a c-clamp with a bit of angle iron welded to it with a window ground in to allow tac welds...Union Ironworker 33 years...
    pitman likes this.
  14. 55Thunderboy
    55Thunderboy
    from NYC
    guys i plan to jump back on this project this week my buddy is going to do the welding for me at my garage/ we are going to use my Miller Matic 211 Mig with stainless wire and tri mix gas. When **** welding tubing together should we leave a gap between the two sections or just **** them up against each other?
    What would give the best and strongest weld? we could V both sections as well with a grinder i suppose.
  15. mgtstumpy
    mgtstumpy
    Good article on Jeff Lilly restorations.
  16. When I was welding 3" and smaller stainless pipe, I did this with a half dozen pair of vise grips. You also need some straps or blocks for the far end.
  17. a couple pieces of angle iron clamped to hold both pieces end to end, weld the space, the remove the angle and weld it up.
    edit: I see I was late to the party :)
  18. towithome
    towithome
    from oregun
    Listen to this guy, it works perfectly. Weld a 3" piece to each tong and when you have room, just slide in a 12" or so piece of angle and use the clamp in the same manner. Perfect for all situations.
  19. Mr48chev
    Yep, a C clamp with two short pieces of 1 inch angle welded to it so they hold the tube ends together is pretty well standard for **** welding tubing.
    Laying it in a longer length of 2 inch or so angle iron and lightly clamping it works too. You want to be careful rotating it in the angle iron so you don't scratch it though.
  20. I found these listed in the ****** catalog, they are really made
    for building custom headers (****** Alignment Sleeves) available
    for 1 5/8", 1 3/4", 1 7/8", 2" & 2 1/8" sizes. They actually fit
    inside the tubing and the vertical flange gives you some material
    to use as filler. Never tried them, just saw them in catalog.
    John
  21. pitman
    pitman
    One of the fume concerns is if the welding (S.S) produces chrome 6.
    You do not want to breathe this.
    Use a fan, and the great outdoors.
  22. squirrel
    ...or you can do a variation on a theme...
    Two straps of sheet metal, clamped firmly by the hose clamp. Don't cost nuthin, and lets you easily see most of the joint, to get the alignment right and tack in several places.
    You can also bend a 90ish degree angle in the straps, and using three clamps, clamp a TEE tubing joint.
    I wish I'd thought of this years ago. Oh well.
  23. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    I used 2 lengths of angle with 2 hose clamps for straight sections. On bends I used 2 strips of Gorillas duct tape.... one opposite the other. Tacked the sides and peeled it off with final weld later. Kinda ghetto but actually worked great. The Gorilla tape is tough stuff.
  24. Paul
    Paul
    Editor
    How did they mig weld 3" stainless steel exhaust tubing back in the day anyway?
    squirrel and Rex Stallion like this.
  25. 1946caddy
    1946caddy
    from washington
    Actually the proper way would be to TIG weld it with purge gas on the inside or you might get away with a SS flux. If you insist on MIG welding, I would make a sleeve to fit inside of the pipe and leave a gap the same size as the wire your using.
    Blue One likes this.
  26. Blue One
    Blue One
    from Alberta
  27. Blue One
    Blue One
    from Alberta
    Tig would be best for sure and I have actually done some pretty nice Stainless exhaust tubing without a internal purge.
    The trick is a 1/16” Tungsten and very low amperage along with a 1/16” ER347 filler wire.
  28. 1946caddy
    1946caddy
    from washington
    Probably not too critical on a exhaust system but in pipe welding where they can x ray the weld, the back side of the weld has to look pretty good. That's why I suggested flux. Try looking at the inside of your exhaust pipe weld, you might be on to something.
  29. Engine man
    Engine man
    from Wisconsin
    I've used angle iron to align drive shafts for welding. The sleeve clamp with some holes cut in it will work well too.
