Hemi block too far gone to save?
Discussion in 'The Hokey Ass Message Board' started by tjet, Sep 9, 2013.
  1. tjet
    tjet
    Anyone ever sleeve a cylinder this bad? The rest are ok.
      398.1 KB
      194.7 KB
  2. teddyt
    teddyt
    from U.S.
    Very eager to hear the answer to this one :)
  3. randydupree
    randydupree
    from archer fl
    i would sleeve it.
  4. willys1
    willys1
    from South Ga
    I've had worse than that sleeved. No issues. If the rest of that 331 is good, Save it!
  5. 34toddster
    34toddster
    from Missouri
    That can be fixed, I had 3 holes in one and it's still running!
  6. Yea gets a wet sleeve. No biggy if the machinist has any idea in the world what he is doing.
    When I was in High School I helped dannhy killcup (you Nor westerners should know of whom I speak) wet sleeve all 6 holes in a GM 250 block. It was a successfull effort to make big inches from a worn inline 6.
  7. Manic Mechanix
    Manic Mechanix
    I have seen way worse on a salt water marine block. The owner had all 8 holes sleeved. $100.00 per hole. Your block appears as though it could easily be saved with a sleeve.
  8. sunbeam
    sunbeam
    Sleeve it should be fine. Coat the sleeve and bore with KD block sealer and drive it home.
  9. TR Waters
    TR Waters
    from Vermont
    Should be fine with a sleeve.
  10. falcongeorge
    falcongeorge
    from BC
    Thats what they make them for...
  11. ol fueler
    ol fueler
    Way back in the late 50's my partners and I wet sleeved all 6 holes on our 324 inch Fuel Jimmie. Worked fine till a clutch blew and sawed the bell housing OFF!
  12. Yep those wet sleeves will cause that. :D
  13. M224SPEED
    M224SPEED
    from Missouri
    Good machine shop & you will be good to go,it is W/O a doubt worth saving !!
  14. 1933t
    1933t
    from Buffalo NY
    Common with them should be a EZ fix
  15. tjet
    tjet
    Ok - cool.
    Do they use a sealer to keep the water from getting between the sleeve & cyl wall?
    Also, there is a crack that goes down the cylinder. Do they address that before the sleeve goes in (like stop-drill it or something)?
  16. jesse1980
    jesse1980
  17. They will no doubt cut the old cylinder wall completely out. Should have a step cut up near the top of the cylinder and the sleve should have a souolder on it to keep it from settling and yes some sealer of some sort will probably be used to keep the water out of the crank case.
  18. tjet
    tjet
    If they take the wall out, what holds the sleeve in place?
  19. yaidunno
    yaidunno
    from Wisconsin
    It will register in the step cut on the top, and the press fit will come from the lower block area underneath the water jacket. After its pressed in, the block will be decked.
  20. tjet
    tjet
    OK, got it. So the deck area & lower cyl holds it. I was thinking I might need to put some block fill in it (like 1/2 street fill)
  21. slammed
    slammed
    'Sleeve it should be fine. Coat the sleeve and bore with KD block sealer and drive it home.' Dude, slow down and read that SUNBEAM answered your question.
  22. sunbeam
    sunbeam
    Stop drilling the crack is recomened. As to cutting out the old cylinder wall I like to leave as much as possible. It helps to keep the deck ridged. Most repair sleeves aren't so thick that you will remove all the old wall. When you bore for a sleeve you do not go all the way out the bottom you leave a lip at the bottom and the sleeve is driven to the lip. Then the excess sticking out the top is trimmed flush with the deck.
  23. tjet
    tjet
    Good stuff. I'm going to take the block to L.A. Sleeve & get it done.
    Thanks guys :cool:
  24. Mr48chev
    Yep, it's finding a machinist that knows what he is doing and how to do it right.
    It cost me 107 bucks to sleeve one hole in a 350 Chevy block 30 years ago when the going price for a good four bolt block was 100 bucks and I don't know what they would charge now. I ran that engine for a lot of miles in my 48, sold it to a friend and helped him put a re-ring kit in it and I still see the truck he put it in every once in a while.
  25. ol fueler
    ol fueler
  26. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I sleeved a 261 Chevy block that was that bad, and it held up fine.
