Y block intake middle scortched
Discussion in 'The Hokey Ass Message Board' started by Shrekgreen55, Sep 9, 2013.
  1. Shrekgreen55
    Shrekgreen55
    Engine: 1954 Ford Wagon 239 - changed all parts to fit in my 55 F250
    Crank case vent blocked off and placed a pcv valve in intake with a correct valley pan.
    Carb/intake: Holley original with 1955 F250 239 intake
    Truck and engine ran for 35 miles without any problems. But now, this heat problem and some small oil leaks.
    Pcv valve tested before placed in and valve is from a 1964 Ford F100.
    Any ideas what is going on?
    Thanks for any info. Chris
  2. RWENUTS
    RWENUTS
    from Nanaimo BC
    Pcv in the intake or in the pan? Can't tell from your pic.
  3. That is the heat riser to the intake, basically it is a crossover from the echaust ports. Wanna keep it pristine? Block the heat risers, it won't say exactly pristine but win't idscolror as far up the intake.
    It is not a sign of a problem if that is what you are asking.
  4. sunbeam
    sunbeam
    Stuck heat riser or plugged exhaust on one side.
  5. Shrekgreen55
    Shrekgreen55
    pcv valve placed in the extra hole in front of the carburetor and crank case vent tube blocked off.
  6. hoop98
    hoop98
    from Texas
    Difference in pressure in the exhaust causing high flow under the manifold. Restrict or block the exhaust crossover.
  7. RWENUTS
    RWENUTS
    from Nanaimo BC
    Pcv goes in the pan or a valve cover. Not in the intake. Intake supplies manifold vacuum source.
  8. Pops1532
    Pops1532
    from Illinois
    Crankcase vent blocked and PCV installed where it won't vent crankcase pressure is what's likely causing your oil leaks.
    Heat riser causing the scorched paint on the intake.
  9. Shrekgreen55
    Shrekgreen55
    So then, I should do what and place the pcv valve where? Any pics anyone?
  10. Shrek,
    When I have an engine with a rod draft tube I usually stick the PCV valve in the hole that the road draft tube left when removed. You will need to make sure that you n have breathers on the engine normally they are stuck in the rocker cover but sometimes they can be stuck on the oil pan above the oil lever.
    If the only breather you have is your oil fill tube more ofter then not you are only venting your lifter valley and not your crank case.
  11. hoop98
    hoop98
    from Texas
    That's the correct PCV location, the port is connected to both plenums.
  12. F-6Garagerat
    F-6Garagerat
    The F100 pcv is br*** and screws into the intake. Had one before.
  13. RWENUTS
    RWENUTS
    from Nanaimo BC
    So is that the manifold vacuum source for the pcv?
  14. hoop98
    hoop98
    from Texas
    On the later factory manifolds yes, it was a screw in PCV valve, V100 or Fram FV100
  15. Shrekgreen55
    Shrekgreen55
    Rwenuts....yes, that is where I placed the pcv valve (hoop98 picture).
  16. Shrekgreen55
    Shrekgreen55
    I guess I need to make a hole in the old crank case vent (blocked off now), place the pcv valve inline and run the hose to the valley pan or ???
  17. Pops1532
    Pops1532
    from Illinois
    No, that won't vent anything as you'd be tying it right back to the crankcase.
    The PCV needs to be placed where it will vent the crankcase.....valve cover, old vent tube, oil pan or even the valley cover. The hose will then need to run to a vacuum port....like the one on the manifold where you currently have the PCV valve.
    Where do you currently have the hose hooked up?
  18. hoop98
    hoop98
    from Texas
    The factory valley cover had oil fill at one end with a breather cap and the PCV hose went to the back where the old road tube was.
  19. Easy going
    Easy going
    from Illinois
    For many years, Ford simply either vented internal pressure of the engine right back to the air cleaner.
    They used an oil filler cap in some instances, and ran a rubber tube to the side or the underneath of the air cleaner base.
    Look at a 428 Cobra Jet engine on the web, if it has the air cleaner on it, you will see exactly what I mean.
    For a pcv, ford went from a valve cover port, usually on the p***enger side valve cover to the intake, some plugged into a spacer plate under the carb.
    Hope this helps?
  20. hoop98
    hoop98
    from Texas
    That was called the Closed system, any excess pressure vented to the air cleaner instead of the Atmosphere.
    Normal ventilation air was drawn from the AC housing to the crankcase out the PCV hose or grommet to the valve to the intake.
    Under heavy load with no vacuum it would backflow and vent pressure into the AC housing where it would be pulled into the carburetor and burned.
    Here are some pics of the Y-Block PCV Valley Cover.
  21. sunbeam
    sunbeam
    There a cl*** one and cl*** two PCV systems. The early or cl*** one used a valve and a vent usally the oil cap. worked well at an idle or high vacuum times not at wide open throttle. Type two vented the system to the air cleaner using the air flow into the carb to pull on the crankcase vapors at wide open throttle.
  22. fastcar1953
    fastcar1953
  23. Shrekgreen55
    Shrekgreen55
    Great info and pics! I went with a 3/8" hose from the valley pan to a 1/2" hose to the pcv valve into the intake manifold. But, how was the set up back then because I placed on an earlier type Y block valley pan.
