Where do you get you rear end work done around L.A.?
Discussion in 'The Hokey Ass Message Board' started by fltnlow, Sep 9, 2013.
  1. fltnlow
    fltnlow
    from Burbank
    Broke some teeth on the pinion gear in the roadster unfortunately and just got around to dropping the center section to assess the damage, but not sure where to take it to get setup.
    The car has a 58 pontiac/olds rear and I'm also looking for a gear set (4.88 or 5.13s) if anyone happens to have something available.
    I talked to Hooper's a little while back, but they didn't instill any confidence in me that they were comfortable working on the rear since they couldn't quote me on parts or labor
  2. dreracecar
    dreracecar
    from so-cal
    The GEAR SHOP (FORMALLY TOMS DIFF) in Paramount
    1-562-634-1396
    Tip: buy gears yourself and just have Gary do the setup right around $275 plus any bearings & seals
  3. hotrod40coupe
    hotrod40coupe
  4. barebones32
    barebones32
  5. GassersGarage
    GassersGarage
    Call Groucho at Groucho's Performance.
    (818)765-1327
    10733 Wixom St, Sun Valley
  6. arturo7
    arturo7
    The Gear Man in Garden Grove
  7. Ramjet on San Fernando Rd in Sun Valley. Ask for Eddie. He's done several for me over the years. I may also know of some gears. PM me
  8. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    Hell I heard you could get your rear end worked over on just about any street corner in LA :eek:
  9. Pewsplace
    Pewsplace
    Ron's Rear Ends in Sylmar 818-361-5457. He knows rear ends better than most.
  10. Did you ever sort this out? I know a place that does great work (I've seen your car locally), and have a friend that has some of those "low" ratio gears
  11. toxic waste
    toxic waste
    from Iowa
    Fabcraft at 1-800-208-8242
    They have everything for rebuilding the 1957 -1964 Pont/Olds 9.3" rearend. They sell gear sets from 2.56 thru 6.14 ratios. They have a store on ebay. www.fabcraftmetalworks.com
    I just talked to them today. Call and talk with them first. They sale a book on how to set this rearend.
    Toxic Waste
  12. amadeus
    amadeus
    Sutton Engineering
