Help! Need to replace a steering wheel
Discussion in 'The Hokey Ass Message Board' started by GrantParker, Sep 10, 2013.
  1. GrantParker
    GrantParker
    from Atlanta
    Folks, I have a '54 Chevy p/u with a really ugly after-market steering wheel. I bought an original wheel which was in pretty good shape. Then I removed the after-market wheel. That was easy. But then I came across a plate that someone had ground down to an odd shape. The after-market wheel was screwed in to that. Underneath it, resting on the steering column, is the original collar that fit on the factory steering wheel.
    That plate has to come off, but I am stymied. Does this call for a gear puller? I am ready to get one but wanted to solicit opinions first. Please see the photos.
    Thanks.
      381.6 KB
      403 KB
      410.7 KB
  2. hotrodharry2
    hotrodharry2
    from Michigan
    I would try a wheel puller first. Looking as good as I can through old mans eyes, it looks like the very center maybe welded to the steering shaft. So I'd use a puller and watch it for bending the outer plate and not giving around the shaft. You may have to heat the center up with torches but being careful not to cause heat damage to the bearings and whatever else maybe in the area. Good Luck.
  3. GrantParker
    GrantParker
    from Atlanta
    Yow. Welded? Why on earth would anyone do that? OK, thanks, HRH2.
  4. Holy ****! What a mess that plate is .
    I'd start with a standard steering wheel puller.
    You may need to drill and tap new holes in that plate for the puller to work.
    Look well for a weld around that shaft, if it is welded you can cut it with a hole saw that will just fit over the threaded shaft. The shaft will act as a guide so you can remove the center pilot drill, the hole saw will stay centered and cut the weld
  5. Keep
    Keep
    That is one ugly steering wheel adapter.
    Not sure it was welded, but it does look like there is some solder/brazing there.
  6. 5559
    5559
    from tn
    what a hatchet job---makes you wonder how some people survive--use a gear puller slowly--maybe a little heat &it should come apart . If its screwed beyond repair , it would be a good time for a little later model column
  7. Looks like somebody cut the center out of a stock wheel, then butchered it into a 'adaptor'. You might be looking for a new column....
  8. GrantParker
    GrantParker
    from Atlanta
    I suspect that is the center from a stock wheel, and I am fervently hoping I can get it off. I have priced columns.
  9. barobert
    barobert
    That looks realy ugly, look for another steering column, safty comes first.
  10. jcmarz
    jcmarz
    from Chino, Ca
    That looks welded which it should not be and any amount of pulling will not remove that. I think your best shot is to get a Dremmel or even a hack saw and cut that thing like a pie. The welds can be broken by moving the cut piece back and forth till it breaks. Once the pieces are off, file smooth whatever remains.
  11. GrantParker
    GrantParker
    from Atlanta
    I'll take a closer look. I have nothing to lose by applying some heat and pressure to remove the butchered plate. I'd like to kick the a** of whoever did this. Thanks, all.
  12. Well, it can't hurt to try a puller on it.
    Harbor Freight makes a wheel puller kit that's pretty slick, I've used mine dozens of times now. Either it will pop off easy, or it won't.
    The next step is to see how ugly it is with it off, and decide if you can put a stock wheel back on there.
  13. GrantParker
    GrantParker
    from Atlanta
    I just returned from Harbor Freight with that wheel-puller kit, rustynewyorker. I needed one anyway, and I cannot think of a better way to break it in.
  14. 37hotrod
    37hotrod
    Don't say "break" and "Harbor Freight" in the same sentence. Good luck getting that off. Hope nothing else on the column got "fixed" at the same time. Keep us posted.
  15. B.A.KING
    B.A.KING
    ^^^^^ yep I am afraid you will "break" it in alright. I would look for another column. Good luck
  16. Mr48chev
    Once you get that mess off you are still going to have to deal with the column as it appears that the top bushing/bearing is out or severely damaged too. Looking at that again it may be that what I was looking at was the back side of the hub of the stock steering wheel that got knocked off the hub.
    You might want to chase what threads are left and run a nut on the end of the shaft so the puller doesn't damage it any more than it already is.
    That ranks right up there at the top of the "look what someone screwed up before I got it" list I'd have to say.
    Keep us posted on your progress as Inquiring minds want to know how you come out on this.
  17. willys1
    willys1
    from South Ga
    ^^^Yep. Because they couldn't get the wheel off either. Then mounted the adapter to what's left of the original wheel. :eek:
  18. Mr48chev
    Or they were too cheap to buy a 20 dollar adapter. I've run into a few "adapted" wheels over the years but never that big of a mess. They usually took the old wheel off and over to the bench and then cut it down rather than cutting it down in the car.
  19. dirt t
    dirt t
    There are two holes 180 degrees apart that are threaded 1/4 " fine thread. a standard steering wheel puller will pull that hub and expose the original set up.
    Good luck.
  20. 40Standard
    40Standard
    from Indy
    I'd put a new column in
  21. GrantParker
    GrantParker
    from Atlanta
    I put a wheel puller on that torn-up plate yesterday. I applied penetrant and pressure. Nothing. I tightened it some more. That plate did not budge. I will work on it some more this weekend, trying some of the tactics you guys suggested.
    If that doesn't work, I know a guy in Colorado who's waiting word from me to drop a steering column in the next Greyhound bound for Atlanta.
    I would like to find the guy who did this and take the old column to him.
  22. saltflats
    saltflats
    from Missouri
    Would you ask him to bend over?
  23. Once you have a strain on the puller bolt, a good strain, whack the puller bolt with a 2 pound hammer. Works for me and seems like it is always necessary.
  24. GrantParker
    GrantParker
    from Atlanta
    I would ask him to bend over or close his eyes, saltflats -- maybe both.
    Unclee, I have a 2-pound maul back at the house. I will employ it tonight.
  25. On a good day, I can pop them off at a boneyard with just a hammer.
    One hand and one knee to apply pressure to the wheel and one hand for the hammer.
    On a bad day I can't get them off with a puller, a torch, and a sledge.
  26. Stubborn steering wheel removal kit
  27. dirt t
    dirt t
    Take a 4" cut off wheel and cut in until you reach the shaft use puller or slice both sides and whack it with a BFH.
  28. See above kit
  29. GrantParker
    GrantParker
    from Atlanta
    I will try cutting the wheel this weekend. My efforts with a wheel puller did not work. BFH is ready.
