Technical Dimension needed 1928-29 front fender lip to lip?
Discussion in 'Traditional Hot Rods' started by jevans612, Sep 9, 2013.
  1. jevans612
    jevans612
    I need the width dimension for front fenders on a 1928-29. Outside lip to opposite fender outside lip. I thought I saw it in a catalog some time ago but cannot find it now. Help!
  2. RollinRock
    RollinRock
    Jack,
    Have a stock bodied 29 cpe will measure what you need.
    Bob
  3. RollinRock
    RollinRock
    Jack,
    Measured 66.5 in. just in front of radiator for 29 cpe (same for wheel on center).
    Bob
  4. jevans612
    jevans612
    Thanks for the measurement. I'm starting an AV8pu and want to know if a '40 front axle would keep tires under fenders.
  5. verde742
    verde742
    to wide in my opinion..
    also holes for spring, might require having to have main leaf made. 40's had spring in front of axle. so if you use spring perches from earlier axles, which main leaf would you use.
    don't say long shackles..
  6. jevans612
    jevans612
    Could I use the '40 spindles & brakes with a dropped "A" axle and spring?
  7. verde742
    verde742
    Absolutely... that is a very good choice..
  8. jevans612
    jevans612
    Please look at post #4
  9. verde742
    verde742
    wayy to wide...
