PHOSPHORIC ACID - a pictoral
Discussion in 'The Hokey Ass Message Board' started by 53choptop, May 6, 2008.
  1. barney rubble
    barney rubble
    Can I use a rust convertor like Por 15 over the treated metal after it dries? I have some back in a area I cannot get to to sand or try to scuff it up to remove anything left from the treatment.
  2. PetesPonies
    PetesPonies
    from Maryland
    There is real drying if you use the phosphoric acid correctly. Keep it wet as it works, then dry completely with paper towels. At that point, it is ready to be coated. Don't use POR; ****. If you want a moisture cured product, use Master Series silver, then whatever top coat you wish.
    Fortunateson likes this.
  3. 53 COE
    53 COE
    from PNW
    After trying Ospho here and there I really prefer non caustic Evapo-Rust followed by the KBS Coatings products. Their "RustBlast" is a less concentrated product - KBS has the same instruction as many have said in this thread - Do NOT let it dry - wipe it off. It still leaves a protective zinc phosphate coating.
    Here's my results on my wagon roof:
    http://www.jalopyjournal.com/forum/showthread.php?t=834529
  4. Garagekulture13
    Garagekulture13
    I just read this whole topic. Maybe I missed it or it was not mentioned because it was thought to be common sense. But will the phosphorus acid effect wiring, hoses, bushings, etc? I want to use it on my 1950 Pontiac in the wheel wells, a-arms, frame section, etc.
  5. 19Fordy
    19Fordy
    Phosphoric acid is corrosive. I would not use it around electrical wire or connections.
  6. PetesPonies
    PetesPonies
    from Maryland
    That being said, anywhere you can wipe on and wipe off is not a problem. Meaning, don't leave it on, but in my experience with it over many years, it will not damage anything if you wipe it off in an orderly fashion. I keep some in a plastic contain, it's sold in plastic containers. I use it everywhere, just wipe clean.
  7. tlmartin84
    tlmartin84
    from WV
    Picked this up at tractor supply. It was $30.00 but works better than anything I have used or seen........
    Hope you guys can comment on these:
    The directions say NOT TO WASH IT OFF! Says to paint over it with whatever paint you choose. What do you think about that?
    I have been using it in panel seams just soaking them down where sandblasters can't reach. The gray stripes you see on the surface are where it dripped off of the tip of the spray bottle.
    I have used KBS and washed it off. This stuff says it is formulated so you don't have to. Just curious how it will react to paint down the road.
  8. Texas Turkey
    Texas Turkey
    from Texas
    Look at post 37 of this thread--another product with phosphoric acid is called Rust Cure
  9. nexxussian
    nexxussian
    I buy Ospho at True Value.
  10. Texas Turkey
    Texas Turkey
    from Texas
    You have to use common sense using any acid based cleaner or rust remover or converter
    FIRST--any acid will react more with copper(wire) or aluminum(wheels-trim-wire ends) than iron or steel parts and higher temps will speed the reaction and the stronger the acid the more reaction so muriatic acid or other stronger acids will ruin your part or hurt you much faster than phosphoric acid(ospho or whatever it's called) or vinegar --ospho turns rust to an inert form that can be painted over but if the rust is too thick it may only coat the top layer or be too rough to paint smoothly--YOU have to use your judgment --and when the reaction ends it's over
    If you soak your part it will keep reacting when you take it from the solution it is still reacting until it is spent, washed off or neutralized--and if you wash the part where BARE metal is exposed to the air--containing 0xygen--new oxidation in the form of rust if it is iron or steel will happen until the piece is coated with something to seal out the air
  11. 63 Avanti 3137
    63 Avanti 3137
  12. Texas Turkey
    Texas Turkey
    from Texas
    painters here have said PPG paint does not adhere to ospho and to read each paint's tech sheets
  13. badsix
    badsix
    I've been in the auto restoration for about 35 years and use P/A often. I just did a 40 ford sedan roof that had heavy surface rust. What I do is lay out an old towel or two and saturate them with the P/A. then cover that with some light visqueen and let it set over night, the visqueen will keep it from drying out. the next day I remove the towels and wipe it clean. lastly I will wipe with a damp rag. when I have all the rust off I will go over all of it with a D/A and 80 grit. now wipe it until clean with metal prep and i'm ready for primer epoxy or what ever. I know that they say to let it dry, but I can't make myself spray paint over the residue that is left. I want good shinny clean metal.
    Jay D.
  14. OhTara
    OhTara
    Great thread !!! I feel like i've been reading it since 2008 ... but it never get's old!
  15. Los_Control
    Los_Control
    from TX
    Acid is great, same time it is cruel. Going to post 2 photos. I used acid to clean my body panels on my avatar. Because I am a cheap **** and no access to decent sandblasting. First photo is a fender from my avatar, it cleaned up nice along with the other fender, hood etc... I parked in my office. Because that one piece did not get the acid neutralized properly. Even though parked inside, it flash rusted faster then normal. IMG_20191015_141001611.jpg
    I am a noob with acid, I use ospho, I have phosphoric acid, I have muriatic acid.
    Probably doing it wrong. But it does work.
    The next photo is simply my truck with ospho acid on it. I already brought the front to bare metal and primer. The bed & running boards is covered with ospho. Until I get time to remove them anMy pressure washer washes the ospho off to bare metals clean it. Just saying different acids have different uses. These bedsides will get the roughest muriatic acid. But not til they are removed and moved 500' to the back yard away from the vehicle.
  16. Uncle Bob
    Uncle Bob
    from Salado, Tx
    To save me key strokes I refer you to post #84 I did back when complete with pics of results. You didn't list washing off the wet conversion coat so guessing you didn't do that. The black/white residue/buildup is what you get when you don't wash off the acid wash. Sounds counter intuitive but it is a necessary step.
    Dave Kurak likes this.
  17. mr.chevrolet
    mr.chevrolet
    i use OSPHO on rusty stuff, mostly parts/places like inner fenders, frame stuff, inside doors & underneath fenders, spray on with hand pump sprayer (old windex sprayer), I brush it around with an old toothbrush, let dry, no wiping/rinsing, then paint with oil based paint. holds up very well. white part is dried OSPHO.
  18. Slick111
    Slick111
    OSPHO behind hidden brackets lap seams cant be reached by blasting then Rust-Oleum primer holds up for years in my Seattle wet climate
  19. Dave Kurak
    Dave Kurak
    Thank you for the response ... and you're right - we did not rinse it off. Your probable ***umption that we jumped right in without the proper research is also right, but it's a good learning experience and something we should be able to address with a bit more work. Thanks again for the quick reply and pointer back to #84!
    Uncle Bob likes this.
  20. jimmyg_146
    jimmyg_146
    Great Info, I'm currently using eastwood fast etch and so far it has worked really well. i picked up this 54 that was sandblasted then sat for awhile and eventually rusted. I picked up a SCT contour with a wire wheel and it worked great! Next i will apply epoxy primer i purchased the eastwood and will see how well it sticks to the metal. i plan to knock the phosphate and neutralize the metal i do not want to use water so i am trying to figure out what's the best neutralizing agent before I DA and clean with acetone.
  21. overspray
    overspray
    Great thread that I haven;t read for several years. I just want to add this information.
    Why can't you put body filler or epoxy primer over metal prep or self etch primer?
    I did actually ask a chemist, (John Hatton) who developed one of the best polyester resins used in body filler, why you can't put filler over etch primer. His answer was, that the acid in the etch primer slows the cure of the polyester resin in the filler. Filler companies don't recommend using their products over self etch primer, because most users cannot tell if there is any acid left in the primer film. Self etch primers are usually mixed 1 to 1 with a converter/hardner that is a solvent with 5% phosphoric acid (the etch part of the primer). After mixing 1 to 1 the reduced primer has 2 1/2% acid. The phosphoric acid converts with the steel to form iron phosphate, and since acid is constantly converting, usually the rest in the mixture converts with the solids in the primer. The variables are; if you put too heavy of a coat(s) on, excess acid can be trapped in the primer film, texture or deep sandblasting or rust pits could trap acid in the pores/pits/texture. The excess trapped and not converted acid could affect the catalyst of the filler causing slow and uneven cure. Etch primers bond to the metal with both chemical (acid etch) and mechanical (sand scratch) adhesion. On older restorations, sandblasted rusty metal, I sand the blast texture smoothe with 180#, then clean, then etch prime. I prefer using self etch primers followed by a GOOD QUALITY 2K urethane hi build primer. If I'm ready to use filler on an area, I grind off the area and use filler then reprime with 2K. When I put filler on bare steel, I try to make sure the metal is warm (70-80 degrees) so moisture doesn't condense on the surface and the filler through cures evenly and not from the outside in. A light film of (invisible) moisture can condense on the metal surface, which is usually 10-15 degrees colder than the surrounding air temperature. If your shop is at 70-72 degrees, the metal is around 60 degrees-- carefully pre-warm the panel if the metal is cold. This removes the condensed moisture and helps the resin cure evenly. Polyester resin (body filler) just about stops curing below 64 degrees. This means your filler will cure from the outside in and maybe the filler at the metal surface won't completely cure until it's finished and painted and set out in the sun on a 90 degree day. That is usually the reason for cracking and bubbling and rust forming under it from the moisture that condensed on the cold metal.
    Now, putting epoxy primer over self etch is another lesson in chemistry. Phosphoric acid (metal prep/ self etch) can affect the activator/hardner for epoxy primers so it will dry but not cure. If you metal prep/acid etch bare steel, you have to rinse it off and neutralize it before applying epoxy primer. Actually most companies recommend acid washing (for removing rust) steel before applying epoxy primer (read most tech sheets). Most automotive epoxy primers have low to moderate film builds and long cure times and only a few have really good solids content (and film build).
    Here's the SPI tech sheet for their epoxy with OSPHO instructions.
    https://www.southernpolyurethanes.com/_files/ugd/8ced3e_a7a1dc8925de4b5595e82fd43ab7a758.pdf
    warbird1 likes this.
  22. deathrowdave
    deathrowdave
    from NKy
    Last Harley I did had some type of liner in the tanks that came unattached , what a train wreck . Phosphoric Acid , and BBs removed all the liner to bare shiny steel . 24 hour soak , I was amazed
