My 64 needs your help!
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by DevonJordan, Sep 11, 2013.
  1. DevonJordan
    DevonJordan
    After choosing this sight for registration, I now need to set it up..lol So here is the problem... I have a 1964 f100 2wd with the 292. After the fuel filter plugged I had someone tow it.. well, they bent my tie rod tube and she has been sitting since. I have not been able to find one, new or used. I know I could take it to a machine shop, but im trying to avoid that. If anyone has one, or knows where I could find one, id be forever grateful. Maybe someone here has swapped out a front end and no longer has a use for it??
  2. 53fordcustom
    53fordcustom
    Welcome! This is the intro board. Post your question on the main board for help
  3. Hemishovel
    Hemishovel
    Welcome from wi
  4. 1955IHC
    1955IHC
    Welcomr from Es*** Illinois.
    Sent via Western Union Express.
  5. 1955IHC
    1955IHC
    Depending on the severity of the bend I would just bend it back and get the front end aligned. If your worried about strength you can sleeve it by slipping another tube that fits snugly over the original and plug weld in place.
  6. 2racer
    2racer
    lmctruck.com
    45-2002 TIE ROD TUBE-W/CLAMPS 1 REQ 69.95
