Yucky looking tires
Discussion in 'The Hokey Ass Message Board' started by Bubbashead, Sep 4, 2013.
  1. Post Apocalyptic Kustoms
    from Outside
    As stated above WESTLEY'S WHITEWAL BLEACH will clean them up like new. May take a few times but it will bring the color back out.
  2. 327Eric
    327Eric
    I had the same thing happen on my old Chevy. I used brake fluid to shine them up, and a couple weeks later, they turned brown. This was right about the time No Touch came out, and the stuff did the job. It is the only spray on cleaner I have used that actually cleans.
  3. 1955IHC
    1955IHC
    I use Simple Green. I spray it on straight ans it pulls the brown **** right out of the rubber.
    Sent via Western Union Express.
  4. Don's Hot Rods
    Don's Hot Rods
    from florida
    So now not even a 49' Ford with bias plies is acceptable ?? :confused: I think some of you are taking this traditional hot rod stuff WAY too far. It is ok to talk about Marvel Mystery Oil, Cal Worthington, and a fibergl*** bodied Uncertain T, but not this ?? Very confusing.
    Don
  5. 1955IHC
    1955IHC
  6. AllSteel36
    AllSteel36
    I think some are over policing the forums...seems like the OP asked a question that could affect anyone here...and obviously has by the number of informative replies.
  7. TV
    TV
    I also have this problem, I will be trying some of your solutions, thanks for the help.--TV
  8. Roger Walling
    Roger Walling
    I have heard that mineral oil will take the yellow out of white walls. Maybe it will help here.
  9. 1955IHC
    1955IHC
    Or this!:D:D:D:D:D:D
  10. Rusty anarchist
    Rusty anarchist
    from Edmonton
    Spray nine works well. Will also clean the bugs off the front.
  11. CRH
    CRH
    from Utah
    Useless, dumb replies near the beginning. Helpful ideas, answers and advice after that. I have new 16" BFG Long Miler tires from Coker that are doing the same thing, not as pronounced. They are kept inside and have 0 miles on them.
    Bleche Wite (looks like they were bought out by Black Magic) sure works good! I haven't used it on the above mentioned tires, but on others it had done marvels!
