Which fuel pump???
Discussion in 'The Hokey Ass Message Board' started by Br8kNek, Sep 13, 2013.
  1. Br8kNek
    Br8kNek
    I'm ***embling all the new parts for my new 350 long block and I was looking for some info regarding mechanical fuel pumps. I'd like to get a pump with NPT fittings for both the inlet and outlet. The motor is going to be pretty mild. Maybe 300 hp/350tq.
    I've checked out summit, jegs, etc and from what I hear, Carter makes some of the highest quality and most dependable pumps, which is what I'm looking for. I like the Carter M4891 model, but its rated at 120 gph.
    Would that be too much pump for a mild 350 sbc?
  2. fsae0607
    fsae0607
  3. saltflats
    saltflats
    from Missouri
    I am sure it will work fine but you will have to use a regulator if you are running a eddy carb.
  4. Br8kNek
    Br8kNek
    Nope. Going to be running a Holley 4010, preferably without a regulator.
