Projects Inside handle removal 64 F100
Discussion in 'The Hokey Ass Message Board' started by 302aod, Sep 14, 2013.
  1. 302aod
    302aod
    from Pelham,Tn.
    I hope this is the correct place to ask this question. I tried to remove the inside door and window crank handles today. even tried using my GM handle removal tool, but they still wouldn't come off. Is there a special Ford tool?
  2. midnightautosupply
    midnightautosupply
    from mo
    the ford handles are held on with set screws turn handel with knob up look down there it is sometime it will be allen head or phillips head
  3. 5559
    5559
    from tn
    some have an insert that pops out & a screw will be behind it
  4. 302aod
    302aod
    from Pelham,Tn.
    I think minightautosupply is correct. Ford had covers over screws in the late 60s early 70s. I'm sure there are no covers on these different style handles, but didn 't think about set scews. I will look tomorrow. Thanks for the replys.
  5. trevorhood
    trevorhood
    My 63 f100 handles are held on with screws
  6. A Rodder
    A Rodder
    Screws, that is it. The go from handle and hit against the side of the shaft the handle is on, not the end of the shaft. Hopefully that makes sense. Door and window handles are of the same attachment.
