Technical 9" ford rear
Discussion in 'Traditional Hot Rods' started by rwscmf, Sep 15, 2013.
  1. rwscmf
    rwscmf
    from Maryland
    Rebuilding 9" rear. 1957-59 I think.
    Just put new bearings and crush washer in pinion. Torque to 190. I have read a number of different torque test of pinion specs. 13-15, 25 inch. lb. etc. Can't do test, pinion runs nice and smooth. No resistance at all. What am I doing wrong?
  2. Relic Stew
    Relic Stew
    from Wisconsin
    It will probably take more than 190 ft-lb to start crushing the spacer. Once it starts to collapse the required torque drops off.
  3. Hotrodbuilderny
    Hotrodbuilderny
    Ft Lbs Torque has nothing to do with it if you are using a crush collar, you want around 24 inch pounds of drag on new bearings, or a slight drag on used bearings, there is no set torque on crushing a crush collar they all act differently.
  4. USA Tires Sign Joe
    USA Tires Sign Joe
    from Western NJ
    Call TJ in south eastern PA near DE he will straighten you out.
    610-485-4858
  5. wheels777
    wheels777
    from York, PA
    Agreed. IIRC, used is 17 #in
  6. the preload of the pinion is important even if your using a solid spacer and shims as stated above in inch lbs all so the preload of the side bearings
  7. Jalopy Joker
    Jalopy Joker
    good info at: kevinstang.com
  8. more important , the clearance of ring to pinion, OK , maybe not more important , but AS important. I have seen (and heard ) many rearends set up way too close , and they HOWLLLL , I set the clearance a few thousandths looser than specified, ,, ya gotta have some room in there for lube to go between the metal surfaces, ,,, I have set up quite a few that others were afraid to tackle, and haven't had a failure yet,even at over 650 HP,,,,, my process has worked well for me , but, you can go by spec,,, Joe
  9. Tim Irwin
    Tim Irwin
    You have to crush until you have approx. 15 in.lbs. of rotational force. I do it without the seal. Tap the pinion in & out with a br*** punch. Rotate several times to get the bearings to seat. U prefer using a solid spacer vs. The crush sleeve.
  10. rwscmf
    rwscmf
    from Maryland
    Guys, thanks for the info.
