Technical Looking for good flowing air cleaners for 97's
Discussion in 'Traditional Hot Rods' started by gkgeiger, Sep 15, 2013.
  1. gkgeiger
    gkgeiger
    I've read many times from the 97 Guru's that the cheap chrome air cleaners don't flow enough air. Is it just the paper filter causing the problem and will K&N's make them usable or is it the design? I bought a pair of the helmet style cleaners for my last twin carb Flatty and it wouldn't even make it out of the driveway, choked it too bad. If you know of something, show me. Thanks in advance for your help.
  2. Petejoe
    Petejoe
    from Zoar, Ohio
    I've even encountered problems with better reusable filters restricting also. I've been using a "double wrap" from momma's nylons after drilling holes into the re-usables for 5 years now on two engines. I Haven't had any problems with dirt in carbs at all and get great air flow.
  3. Also depends on how big of an engine you are putting them on...
    Cut out every other section on the back half of the filter and use a nylon "sock" that is available, I used them on my Y-block whem I ran the 94's. The socks ae also good for air compressor filters and bead blast cabinets.
  4. Deuce Lover
    Deuce Lover
    Had a 3/4 race flatty in my 36 and ran these aftermarket air cleaners for 3 yrs with no problem.They have replaceable paper elements.Drove from CA to UT over 3 mountain p***es.Never ever had issues.Hope this helps.
  5. SinisterCustom
    SinisterCustom
    I've used ***** hose between carb and scoops before....
    Now I just go BARE.....
  6. junk yard kid
    junk yard kid
    I use stainless mesh i got in a sample kit from mccaster carr. I had a thread on it and the filters i made.
  7. 40FordGuy
    40FordGuy
    I use K&N washables,...so far, no problem.
    4TTRUK
  8. Kiwi 4d
    Kiwi 4d
    Small k&n washables ,just use the correct cleaner . If you are worried about the filter restricting flow drive with out filters for a bit do a plug check ,replace the filters and do the same. If you feel the little chrome cover is restricting flow you can always raise the cover a little so just the lower portion has a shot of direct clean air.
  9. jrsiron
    jrsiron
    I use the K N filters on my flathead with 2 Strombergs. Would not run with the paper filters that came with air cleaners. I put a thick foam rubber gasket on top of elements to raise the top part of air cleaner 1/4". That put a little more clearance between the top an base of air cleaner for a little more air.
  10. Paul
    Paul
    Editor
    it's the helmet style with the sides that taper in at the bottom that is choking the air flow
    regardless of filter
    the cheapo chrome with straight sides and K&N filters work much better
    I've run them on several multi carb setups without issue
  11. Kerry
    Kerry
    Yep, another vote for the K&N's here. I ran K&N's in some small chome bells on my four Stromberg setup on the hemi. Worked great!
  12. 40FordGuy
    40FordGuy
    What Paul said. Save the helmets to put on, after arriving at the show, then change back, for the drive home.
    4TTRUK
  13. ronnieroadster
    ronnieroadster
    Put K&N filters in the helmets you can find them by dimenion they flow great.
  14. BURN OUT BOB
    BURN OUT BOB
    from western AZ
    On my 34 flatty I stacked one on top of the other .Just need a longer bolt.
    If one is good two are twice as good according to Mr. Justice when he was still on earth. Hence JB 80 to compete with WD40. Least that is what he told me.
  15. ROADSTER1927
    ROADSTER1927
    I could not find any k&ns that fit the helmet cleaners. Gary
  16. MBog
    MBog
    I run 94s and cut up some flat K&Ns on a band saw to fit in frog mouths then siliconed them in from the back side...
  17. falcongeorge
    falcongeorge
    from BC
    If the options are *****hose or going bare, I know which I'd choose...
  18. gkgeiger
    gkgeiger
  19. BURN OUT BOB
    BURN OUT BOB
    from western AZ
    I thought I saw some @ O'Reillys auto parts. This was a while back.
