Technical 1932 tank in a model a on a model a frame show me your tank mounts
Discussion in 'Traditional Hot Rods' started by peter schmidt, Sep 15, 2013.
  1. peter schmidt
    peter schmidt
    from maryland
    my 32 tank i got off ebay should be here soon i just want to see how you all are mounting them. i plan to mimic rear 32 frame horns if i can ever find the demensions of them. and make some sort of bolt on bracket to carry the tank. what do you all do to the body brackets on the stock bumber brackets? is it ok without them?
  2. HOTRODPRIMER
    HOTRODPRIMER
  3. Try a search, there has been a few good threads over the years on this subject.
  4. peter schmidt
    peter schmidt
    from maryland
    i did a search and only came up with one or two pictures of brackets by themselves and one was for a box tube framed car.
  5. Crusty Nut
    Crusty Nut
    I bolted the tank and some rear '32 frame horns together and jacked it up into position. Then just connected the dots from A frame to '32 horn.
    Here are some so-so pictures.
  6. clem
    clem
  7. peter schmidt
    peter schmidt
    from maryland
    where did you get the 32 frame horns? any chance you could measure them and let me know the width height ect.? i think im going to try and make my own horns but i want them to look simmilar to the 32s. im not gona run the covers tho. yours looks great
  8. jlhelm
    jlhelm
    from Minnesota
  9. Crusty Nut
    Crusty Nut
    I got the horn cut offs cheap on ebay. There from ASC or some other aftermarket frame. It's kinda tough to get any decent measurements with the tank and covers on. Seems like a frame print from Westscotts would have everything you need to make them.
  10. peter schmidt
    peter schmidt
    from maryland
    is that the link hotrod primer posted it wouldent let me download ill have to try it on a real computer at home
