old tow dolly
Discussion in 'The Hokey Ass Message Board' started by 5559, Sep 17, 2013.
  1. 5559
    5559
    from tn
    hey guys,I'm thinking of buying an old car dolly.The one i found works like a wrecker,itsgot a sling that you back up to the car with -hook to with chains & a hand crank to lift the car with.Has anybody here ever used one . Like i said it looks old & is narrow so it looks easy to pull. Any opinions on a carrier like this.
    thanks------:confused:john
  2. Swifster
    Swifster
    You have to watch the 'narrow'. I have a 15 year old U-Haul dolly and larger cars won't fit on it. It works fine for my Studebakers, but they are the size of a Nova.
  3. I rented one once to tow a 65 chevy pickup. After about 10 minutes I was wondering why I just didn't rent a trailer. It was scary. Evertime I'd turn a corner the front tires would come out from the straps... I think the truck was too wide. Also, the fenders would get into the side of the truck in turns... and FORGET backing up. It was a mess that I'm glad I survived and no one got hurt.
  4. they work okay. compared to a trailer they are a bi%$#. But way better than no way to get stuff around.
    does it have a center pivot or stiff mounted? if it has a pivot it will pull a lot better and turning will be easier.
  5. Xdrag48
    Xdrag48
    I saw some of them when I was in N.C. A guy were using one to scrap cars.It had 13" wheels on it so the car would not hit it when he turned.They do work,i'm not sure about a long haul.I think a dolly you put the tires on is a safer choice as these are narrow and used a hitch like a tractor.(All the weight is on the hitch when loaded pulling up)
    Steve
  6. Pops1532
    Pops1532
    from Illinois
    I haven't seen one of those for 25 years. As long as it's not TOO narrow it could be a good rig. Just make sure you don't over load it.
