Model T Value
Discussion in 'The Hokey Ass Message Board' started by oldwood, Aug 24, 2013.
  1. oldwood
    oldwood
    from arkansas
    I know what your thinking,not another one of these threads. However I post pics with my questions. I'm trying to help out the family with a price. Thanks
      176 KB
      190.3 KB
      157.7 KB
      199.8 KB
      108.9 KB
  2. Any papers (***le)?
    Posted from my office while pretending to work!
  3. oldwood
    oldwood
    from arkansas
    Arkansas ***le can be gotten. The fenders are there as well as the windshield frame. Is it a 500.00 car or 1500.00 car. Someone give me a range.
  4. HRM
    HRM
    Gotta be worth at least $1500. A ***le alone is worth about $500....
  5. oldolds
    oldolds
    You price range is about correct. Things that matter are is motor loose, how solid it really is, are most parts correct for the year. T's had a lot of things changed over the years, so a car with all the bits from the original car will make it worth more money to the restorer.
  6. jkeesey
    jkeesey
    Ask $1,500 and the first to come even anywhere close takes it. The Ts don't go for high dollars unless they are pre 1915. It would double the price if it was proved that old.
  7. oldwood
    oldwood
    from arkansas
    I went and looked at this T a little closer and it does have a Br*** Radiator. I researched Br*** radiators for Model T's and they made them up to 1916. So I am ***uming/guessing its a 1916 or earlier. I'm hoping to buy it right. What ever right is.
  8. Barn Hunter
    Barn Hunter
    It's worth at least 1500. Any less would be a steal.
  9. Terrible Tom
    Terrible Tom
    I agree. $1500 is fair.
    Tom
  10. jkeesey
    jkeesey
    If it has a solid br*** radiator then it would be older but they also had br*** radiator shells that were used on cars up til the Model As came out. I service a 1926 that has a br*** shell on it.
  11. FencePost
    FencePost
    It is early... the hood is much more square then the later years. I'd put it between 1912 - 1915... ad $1500 is a great price for what's there, regardless of if the engine turns over.. looking at the rest of the car I would probably bet it doesn't Br*** radiators did stop in '16 after that it was paint or nickle...
  12. mashed
    mashed
    from 4077th
    $1500? Really?
    I guess I'm out of touch with reality.
  13. jesse1980
    jesse1980
    I would shoot for 1000.00.
  14. tfeverfred
    tfeverfred
    There was one on the Tbucketeers website and it was straight. The guy wanted $500.
  15. hehehehehe I'm with you too :)
  16. tubman
    tubman
    If I hadn't already paid $600 for a fibergl*** tub (looks to be pretty good to me), I'd give $1500 for that all day long (given the body is not all rusted to ****). I would sell the "T" parts, and come out way ahead. And an available ***le? If I were closer to Arkansas, I'd be on that like a rat on a Cheetoh!:D
  17. dirt t
    dirt t
    I think $1500 is a bit low. 2 to 3 thousand would be closer. Try fordbarn.com it's a sister to the jalopy Journal.
  18. falcongeorge
    falcongeorge
    from BC
    A tub with fenders...Drooool. Wish I had $1500 to spend...Man, what I could do with that.
  19. If somebody took a little time to clean it up and go through and inventory the parts, that alone would push the selling price up a good bit. Some fresh primer, even more. Early T's do not grow on trees anymore.
  20. tfeverfred
    tfeverfred
    The one from Austrailia, with fenders, in this months Street Rodder would change your mind. It's fantastic.
  21. 29pu
    29pu
    From what can be seen in the pic`s my quess it`s a 16 if all parts are correct on it.The hood looks like it`s steel.The 15`s had alumunim hoods.On the engine block on the left side ,behind the water outlet should be a date cast in the block ie 32316 whick would be march 23rd 1916 that would be the casting date of engine if the engine is orginal to car.I see some early stuff on there that cost more than the later stuff.15`s and 16`s are desirable in the restore world like 32`s and 34`s are to hot rodders.
  22. lakeroadster
    lakeroadster
    from *
    So that means you don't have a ***le, right? If you can get $1500 take the money and run.
  23. As a further note, in some states a ***le or not doesn't mean ****, it's easy to get one if need be, so it only is an issue to buyers from states where it's not easy to get one.
  24. falcongeorge
    falcongeorge
    from BC
    Oh, I would DEFINATELY build it full-fendered, NO QUESTION!
  25. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Why do some sellers insist on blowing a fresh slop of primer on everything they sell? Fresh primer on a car for sale is only going to make prospective buyers offer LESS. Most buyers will want to actually see the metal, etc. and will only think you're trying to hide ****py metal or quickie body work. The eventual buyer is only faced with an additional coat to sand off.
  26. Squablow
    Squablow
    Around here, $1500 would be a steal for that. Could probably get double that with a proper ***le.
    As for the primer thing, it's a sad but true type situation, at least, in my personal experience. I don't like to buy anything in primer, but I've had cars sit for sale for months without a taker, then prime it all one color and give it a good detailing, then sell right away. When it comes to selling stuff on the internet, having it look good in a picture seems to make a world of difference.
  27. oldwood
    oldwood
    from arkansas
    There is no primer. The paint was stripped years ago. I'm trying to buy it but the owners daughter thinks its worth more than I want to give , especially with no ***le. I would be buying it to re-sell.
  28. Barn Hunter
    Barn Hunter
    Sooooo.....What is the asking price?
  29. falcongeorge
    falcongeorge
    from BC
    helps hide the sins of the past from the unwashed m***es??:D
  30. nailheadroadster
    nailheadroadster
    The nickle plated radiator SHELLS in 26 &27 were stamped out of br*** and had round holes to hold the lacing. The painted shells were stamped out of steel and the lace holes were rectanglular with a notch in them.
    But... 16 and earlier radiators were made of br*** and much more angular than the newer shells. No way anyone could mistake one for the other.
