40 GMC panel vin tag
Discussion in 'The Hokey Ass Message Board' started by wheelsup56, Sep 18, 2013.
  1. wheelsup56
    wheelsup56
    from so.jersey
    Is this a vin tag for this truck or just body manufacturer?
  2. HOTRODPRIMER
    HOTRODPRIMER
    It says truck on it as plain as day! HRP
  3. wheelsup56
    wheelsup56
    from so.jersey
    I know that but is this a vin tag or body model from another company? I don't have a ***le and this vehicle was a WW2 ambulance... Yellow truck and coach manufacturing...
  4. the-rodster
    the-rodster
    There were no such thing as VINs in 1940. States either used the body serial number or the engine serial number for ***le purposes.
    That is the body serial number, and could be used to get a new ***le.
    Rich
  5. txturbo
    txturbo
    There is no VIN....only model and serial number. That's all you get before the late 60s.
  6. wheelsup56
    wheelsup56
    from so.jersey
    Its also mounted under the dash
  7. C.R.Glow Neon
    C.R.Glow Neon
    from stockton
    look on the frame rail right front, should be numbers stamped, the AC 102 is the series, my '40 GMC suburban was AC101
  8. wheelsup56
    wheelsup56
    from so.jersey
    Is it on the top? Rails have a lot of paint on them
  9. tb33anda3rd
    tb33anda3rd
    on my truck ['39 gmc] there was no numbers on the frame, i used the serial number on that tag under the dash.
  10. SMOG_GUY
    SMOG_GUY
    from Dinuba
    I have a 1939 GMC AC 152 flat bed.
    That tag on the inside firewall is what you're looking for.
    I do California smog check everyday. That's a highly regulated test.
    VIN since about 1980 is 17 digits but as far as CA is concerned, that tag you found IS the VIN tag.
    Model number and or serial number IS the VIN in CA on pre-1980 vehicles.
    Otherwise we would have to send EVERYTHING we check before 1980 to have an alternate VIN plate installed. We don't do that except in very special cases.
    Mis Dos Centavos
  11. Serial number is the VIN. It's old enough it could have been ***led on the engine number instead though.
  12. pasadenahotrod
    pasadenahotrod
    from Texas
    That is the tag by which the vehicle would have been registered for civilian use after military service. The ch***is was GMC and the body by Yellow. As an example from these times, motorhomes are ***led by the tag information on the coach body not the ch***is make.
