Projects 1956 Divco Project: Day 1
Discussion in 'The Hokey Ass Message Board' started by divcotruck, Sep 18, 2013.
  1. divcotruck
    divcotruck
    ***pics below
    So I finally got her in some pretty awesome storage and today we got some dirt on our hands!
    We had to air her out, smelt pretty bad like mildew to be honest. It's probably the rotting wood between the panels. I hope I'm not dealing with asbestos as there seems to be some fiber stuff in the back!
    Here are some pictures throughout the day. We got both doors off. I almost killed myself when i debolted a door spring and the spring coiled up as i untightened the last bolt ... lucky i didn't chop my head off!
    We removed the hood panels and most lightings around the truck.
    The plan for this week is to remove the front grill and take out the motor etc. I'm going to attempt to rebuild that ford 300 inline 6 engine though it sounds brand new already!
    Any tips on how to remove stubborn rusted bolts or nails? Thanks
  2. FiddyFour
    FiddyFour
    man, you need to resize your photos... almost impossible to see and make sense of them
  3. divcotruck
    divcotruck
    just noticed that - will do.
  4. divcoguy
    divcoguy
    I can provide some information on restoring this truck if you need it.
  5. divcotruck
    divcotruck
    divco13 that would be absolutely great. you're awesome! today I'm going to try to remove the center piece aka nose. I want to strip her of all wirings etc and prep her ready to be blasted.
    I am not sure what I should be blasting her with? soda, sand, walnut?
    I'm going to "try" to take the engine out by weeks end.
  6. shivasdad
    shivasdad
    from Texas
    If it's the 300 inline then you have a great motor. Easy to rebuild and put some goodies on. Did one last year for a customer and it was strong and sounded cool. Have fun.
  7. HOTRODPRIMER
    HOTRODPRIMER
    Smaller photos would be nice. HRP
    kidcampbell71 likes this.
  8. 3wLarry
    3wLarry
    from Owasso, Ok
    now I can see it...
      487.7 KB
      470 KB
      382.8 KB
      498.8 KB
      502.3 KB
      506.4 KB
      462.2 KB
      476.8 KB
      416.7 KB
      402.7 KB
      498.4 KB
  9. Model T1
    Model T1
    I think one of those would be a fun project and great driver.
  10. 117harv
    117harv
    The OP needs to delete his pics...thanks Larry.
  11. 3wLarry
    3wLarry
    from Owasso, Ok
    de nada...:)
  12. divcotruck
    divcotruck
    will do it was my first time posting pics!!!
  13. divcotruck
    divcotruck
    So today all that was done was the head lights and i was able to snip off a window. Im trying to get the front grill section off but it's a such a pain since most of these rusty bolts are bolted double sided ... honestly driving me crazy because I have to hold one side and twist another? Is there a easier way to do this guys? I mean, chances are these bolts are all going to be replace regardless ... open to ideas.
    I just want to take this engine out but i forsee some big nugget bolts that may drive me crazy.
    For anyone whos done a resto/mod on a Divco or any other truck, what are the usual steps on restoration. Like what would you all tackle first. I've decided to tackle the engine first, but also remove all the "guts" so i can prepare her to get the body and frame. Is that common procedure?
    BTW Can someone tell me how to post nice thumbnails on this board, i apologize for the big pics!
  14. HOTRODPRIMER
    HOTRODPRIMER
    Looks like a great project,,thanks Larry,now I know what I'm looking at. HRP
  15. divcotruck
    divcotruck
    Yes I've seen that website, thank you for reposting it Steve. Here is another site:
    http://forums.d2jsp.org/topic.php?t=67116491&f=140&o=30
    Theres a picture halfway down that shows what I'm trying to do with the front and engine. Just prepping her to get blasted which I'm still confused on what the best method is. I heard Soda is really bad and sand is too rough. Gl*** or walnut?
  16. pug man
    pug man
    from louisiana
    Good luck on the build and I think using walnut shells for blasting would be best for the body.
  17. indyjps
    indyjps
    For rusted bolts a mixture of ATF and acetone is the most effective penetrant. Another method is to heat the bolt, propane torch is ok, and drip wax, the wax will wick into the threads, the heat itself will help. On blind screws,bolts a whack with a hammer and rocking the fastener back and forth helps.
  18. divcotruck
    divcotruck
    Thank you for that tidbit. I actually did buy a torch, not the wax so i should try that -- ive been nervous using the torch with all the fumes around so im going to first try the ATF and acetone penetrant. I appreciate this feedback!
  19. captainjunk#2
    captainjunk#2
    good luck with the divco its a pretty cool looking project
  20. Sometimes it is quicker, easier to tighten the small stuff (1/4, 5/16, 3/8) another 1/2 turn and let them twist off. (not good with blind nuts though)
  21. divcotruck
    divcotruck
    thank you - my days even f'rust'ating - I can't seem to get this bolts off ugh. anyways I'm going to take a rest for a few days because I have a wedding to attend this weekend. I will keep everyone up to date!
  22. divcotruck
    divcotruck
    there's so many blind bolts it's driving me a bit coocoo haha
  23. divcotruck
    divcotruck
    ImageUploadedByH.A.M.B.1379650607.195838.jpg well I went back and guys - we did it!
  24. divcotruck
    divcotruck
    ImageUploadedByH.A.M.B.1379890224.285774.jpg ImageUploadedByH.A.M.B.1379890238.563866.jpg ImageUploadedByH.A.M.B.1379890254.794926.jpg
    i am trying to remove this ford 300 engine. anyone know where I could begin?
