GM NV3500 5 Speed
Discussion in 'The Hokey Ass Message Board' started by 48FordFanatic, Jan 12, 2012.
  1. firepilot
    firepilot
    I am just putting my set up together here is what I used,
    1. 2004 GTO throwout bearing
    2. pre 86 168 tooth flywheel and clutch kit
    3. Pete & Jakes model A brake and clutch pedal kit(2040?) with a wilwood mc with a 3/4" bore. stock on the GTO was .70 so I am at .75 should work fine.
    4. trans is out of a 1999 S-10.
    I'll post pictures when I get it all installed, the shifter falls right where I need it in my 31 A coupe. I payed more for the pete & jakes stuff than the trans. This all on a sbc 350.
  2. 345winder
    345winder
    what is the engine this trans going behind, because if its a sbc,(pre 1986 will need a pre 1986 168 flywheel),,( post 1986 will need a post 1986 168 flywheel) ,,pretty sure a 4.3 flywheel will not work..
    im collecting parts for my 1934 tudor im gonna start building soon and it's getting an Nv3500 trans,,
  3. junk yard kid
    junk yard kid
    Yep thats true, thats what i did. I have the setup unused, id sell. But im not sure if hillbilly heaven is anywhere near me.
  4. 345winder
    345winder
    i already have the trans,,, :D ,,,
  5. junk yard kid
    junk yard kid
    I was offering to sell the clutch set up.
  6. hotroddon
    hotroddon
    Applications
    1993–1998 Chevrolet & GMC CK with 4.3 liter V6
    1999–2006 Chevrolet Silverado 1500 and 2500LD
    1999–2006 GMC Sierra 1500 and 2500LD
    1993–2003 GM S (S10 etc.) trucks with 4.3 liter V6
    1994–2001 Dodge Ram 1500
    1994–1995 Dodge Ram 2500 Light Duty
    1994-2004 Dodge Dakota
    2000-2001 Jeep Cherokee with 4.0L/AMC 242 I6: NV3550
    2000-2004 Jeep Wrangler TJ & LJ with 4.0L/AMC 242 I6: NV3550
  7. Does anynoe have the measurements form the front face to the shifter locations on the S10 version, and the full size? Further up in the post, reference is made to the s10 shifter being located on the tailhousing.
  8. toreadorxlt
    toreadorxlt
    from Nashua, NH
  9. rottenrods
    rottenrods
    I have had to replace second gear shift fork a few times. I suppose if your driving miss daisy they are ok but mine has been a pos. Apparently there are two different types, the best has an adjustable shift tower that will keep from breaking shift forks
    kidcampbell71 likes this.
  10. Hyway Hauler
    Hyway Hauler
    I have a NV 3500 (Getrag 5 speed) in my '31 Chevy Truck. It's out of a '90 GMC that had a 305. I bolted it to a pre-'86 SBC, with stock Slave. Used Luk flywheel and Luk 10" clutch. (had to buy new because the 305 stuff was 1 piece rear main seal)
    I am running Pete and Jakes pedal combo with Wilwood Masters.
    I recently bought this really cool Short Throw Hurst Combo from a guy selling them on Egay...200$
  11. porkchop4464
    porkchop4464
    This thread got me what I needed. I love teh Hamb!!!!!!!
  12. 62chevy302
    62chevy302
    from east tn
    im getting ready to do this also. ive got a 99-07 nv3500 to put behind a 283. why do you use the 4.3 clutch instead of the 5.7?
  13. SOCAL PETE
    SOCAL PETE
    from Ramona CA
    I ran one behind my 383 stroker in my 60 Apache. Drag raced it and drove it daily. It was noisey but never failed. I'd mashed the living snot out of the thing and it still ran a 9.2 in the 1/8th. Losta wheel spin. Of course when you creat traction you will find your weakiest link.
  14. 73RR
    73RR
    I'll add this for folks new to the thread...the AX15 is also a stout 5-speed and Novak has an adapter that allows you to use a GM oem bellhousing so some of the clutch/flywheel issues might go away.
    A warning at this point is that the AX15 was used in many many different vehicles with a variety of input shaft lengths.
    Some of the GM applications might be simple bolt-ups, not sure, dunno anything about GM stuff.
    Info: http://www.qualityengineeredcomponents.com/?page_id=69
  15. 62chevy302
    62chevy302
    from east tn
    will the 5.7 clutch work?
  16. Fordrust
    Fordrust
    I have a 2000 s-10 NV3500 that I am trying to mate to a 1967 283 for mywife's 1949 Ford f-1. Can't seem to find a clutch and pressure plat to bolt to a 168 tooth flywheel. This is a two-piece rear seal small block chevy I am and the pressure plate bolt pattern is on an 11" circle. Any help would be much appreciated.
    Fordrust
  17. maverick3316
    maverick3316
    I know this thread is old, but maybe people have some new info....
    Will this transmission hold up to a mild (less than 500hp) bbc?
  18. treb11
    treb11
    I'm using one in my '40 pickup behind a mild SBC. I had one in a 95 gmc and went 200K + with it. A little work with a tape measure showed that the mount location is the same as a T400, so a regular CE trans plate for the x member was perfect. shifter comes up in just the right place in the floor. I will be trying to adapt the Mustang clutch cable to the stock pedal ***embly and the throwout arm per a thread on here
  19. lebl468
    lebl468
    I am planning one of these in a 36 sedan behind a SBC. Still working out the details.
  20. Okie Pete
    Okie Pete
    Thanks for the info.
  21. i ran one behind a 348 in my 55 chevy and loved it. several buddies ran them too. they seem to hold up well. i've got behind a 354 hemi in my 48 plym but it's not on the road yet. check out "core shifter" they resurected the old hurst designed shifter. http://www.core-shifters.com/servlet/StoreFront
  22. gimpyshotrods
    gimpyshotrods
    +1 On Core shifters. I run on on the T5 in my Falcon. Works like a dream.
  23. ibbuckshot
    ibbuckshot
    I know this thread is a bit old but I may be able to shed a bit of light on the subject. I have built a 32 Ford extended cab pickup. I used an old sbc 327 hooked up to the NV3500 also known to me as a Getrag 290. the rear is an eight inch ford out of a 76 Ford Mavrick (2.73). We recently took the truck from Ocala, Florida on a 2800 mile field trip out and back to a car show at Mc Garther Field out on Long Island, New York. I will report that it will be a cold day in Hell before I take my little truck back to New York or New Jersey again. Anyway, with this set up the truck cruses at about 65 mph with the engine turning about 1500 to 1600 rpm. These results were the goal from the start and everything seems to have worked out as planed.
  24. ibbuckshot
    ibbuckshot
    I tried to up load a picture of the truck but the window error says the file is too large - what ever that means? Yes, that means the file is too large but with my limited computer knowledge I will have to learn a bit more about how to do it.
  25. tubman
    tubman
    What did it take to adapt this transmission to the 354. This would solve some problems for me. While I'm asking, has anyone else out there run these behind anything other than a Chevrolet?
  26. 73RR
    73RR
    If you use a trans from a 4.7 - 5.2 or 5.9 Mopar then it will, of course, have a small block bolt pattern and the 'usual' LA bell housing adapter is all you need ...well besides the flywheel stuff. See info on my web site on various flywheels.
  27. redwilly1949
    redwilly1949
    I used one in my 40 sedan and did not like it at all. Came from around a 94 S10 with 4.3( had an external slave and shifter was closer to the firewall than the later ones). The shifter was in a good location but it just did not shift real smooth. I replaced it with a world cl*** T-5 and I am much happier. I have about 6000 miles on the T-5 and it shifts way smoother. I have a .030 over 350, flat top pistons, mild cam and have no issues with the T-5. I would not recommend the NV 3500, it did not work well for me.
  28. 34toddster
    34toddster
    from Missouri
    I've had 2 of these and liked them, how many miles on the one you had Redwilly?
  29. need louvers ?
    need louvers ?
    Just curious about the gear ratios in these for a future project. Does anybody have a list of them?
