1950 Chevy Lowering Blocks and U Bolts
Discussion in 'The Hokey Ass Message Board' started by SuRfAcE_RuSt, Sep 18, 2013.
  1. SuRfAcE_RuSt
    SuRfAcE_RuSt
    Alright, attempted to lower the *** end of a '50 Chevy and ran into a snag. Typical Autozone lowering blocks are too wide for the Ubolts and pads on the rear end. Also no one seems to carry the Squared off U bolts.. Does anyone sell skinny blocks and long Squared u bolts to fit these early GM cars?
  2. shifflett
    shifflett
  3. dt50chev
    dt50chev
    Chevs of the 40s as noted above. You can also find the correct ones listed on ebay. 3 inch blocks is about the max you can use without getting into scrub line issues.
  4. jonzcustomshop
    jonzcustomshop
    you can have a trailer/ spring shop bend some u bolts for you.
  5. cederholm
    cederholm
    I used JAMCO for my '53.
  6. pdunn10
    pdunn10
    nostalgia sids sells them
  7. SuRfAcE_RuSt
    SuRfAcE_RuSt
    Thanks for the replies, I guess I'll ****** a pair off ebay. And yea dont wanna get too low with that torq tube. Thanks again
  8. Rocket88
    Rocket88
    make some............
  9. hottweelz
    hottweelz
    from So. Cal
    Our block kits are designed for the 1.75" wide springs and have 2 pin locations for the stock torque tube rear end or a late model rear end. Available with late model round u-bolts or stock square u-bolts.
