Projects International Harvester guys.....
Discussion in 'The Hokey Ass Message Board' started by St. Louis Cummins, Sep 19, 2013.
  1. St. Louis Cummins
    St. Louis Cummins
    I need help with some measurements for the grill shell for my truck. I found a 39 international grill shell to use in conjunction with my 41 kb1 international cab. I'm looking for help with spacing between it and the firewall/cowl area. Front to back and too to bottom. Thanks in advance
    -chris.
  2. SMOG_GUY
    SMOG_GUY
    from Dinuba
    Do you want us to meaure a K or a D? You've got me confused.
    It sounds like you're mixing models
  3. Terraizer
    Terraizer
    The D series grill was never used with the K/KB cab so not sure what you are wanting measurement wise. The D series cab is way different then the later K/KB cabs. I have both D series trucks and K/KB truck so i can get you some measurements.
  4. St. Louis Cummins
    St. Louis Cummins
    I didnt know the 39-41 cab was different. Im still learning about these trucks. I apologize.
    what about measuring from a spot on the grill to say the door pins? Top and bottom.
  5. SMOG_GUY
    SMOG_GUY
    from Dinuba
    I guess you need to post a picture.
    I can't see what good this measurement would do anyone.
    D series was 1937 to 1940
    K was 1941 to 1949 (KB).
    Different trucks.
    If you're mixing models you'd have to fab a hood if you want a hood.
    And if you're not running a hood, why worry about meaurements from grille shell to cab?
    I've got both models D and K. Glad to help you figure out what you want.
  6. 1940D2
    1940D2
    I have a 40 D2 with ****er fly hood I think the 41 kb has a hinged hood
  7. SMOG_GUY
    SMOG_GUY
    from Dinuba
  8. St. Louis Cummins
    St. Louis Cummins
    Yep my cab still has the hinges on it.
  9. St. Louis Cummins
    St. Louis Cummins
    Im looking for 39 front fenders also if anyone knows of some.
