1953 Hudson HORNET 3-SPD - Grinding noise in low gear
Discussion in 'The Hokey Ass Message Board' started by thib, Sep 19, 2013.
  1. thib
    thib
    Hello,
    My Hornet goes fine trough the gears but the first gear is making an horrible grinding noise.
    Sounds like I'll have to pull it out of the car to change *something* but I wanted to be sure it couldn't be solved with adjustments.
    Here is a video I just took. When you see I put the first again this is of course while releasing the clutch from under the car.
    http://www.youtube.com/watch?v=rE6vFXlr8qE
    Thanks for any though.
    Thib
  2. dtracy
    dtracy
    Front bearing in the transmission, the one on the input shaft.
    Dave.
  3. thib
    thib
    Thanks Dave,
    You're speaking about #30 right ?
    I'm wondering how the noise only happens in first gear and not in second, third or reverse. Don't they all rely on that bearing ?
  4. JohnEvans
    JohnEvans
    from Phoenix AZ
    Sounds like a bearing noise for sure. drop the trans and pull it apart you will soon see what is the problem.
  5. thib
    thib
    Will definitely do it.
    Oh and I was wondering what is the purpose of the two solenoids (one at each side). Overdrive ?
    They aren't connected to anything. How should I wire it ?
  6. hudsonjoe49
    hudsonjoe49
    Sounds like you have an overdrive unit trans. One is a solenoid and the other is a governor. You have to run a cable for the mechanical part of the overdrive, and then run a toggle for the solenoid.
  7. hudsonjoe49
    hudsonjoe49
    Also check and see if your lever on the side of the trans is engaged all the way. If it is in all the way the trans will freewheel until the solenoid is engaged and then you will be in overdrive. I think I said that right.hahaha
  8. thib
    thib
    Ok so if I understand well when I'm running I first pull the cable under the dash then toggle the solenoid on to go in OD.
    Also the car has been converted to 12v; is it going to blow ?
  9. thib
    thib
    Went to the garage today to pull the trans covers off.
    Made the same video but with an opened gearbox.
    Cogs look great so I believe it's a bearing problem. I'll figure it out once it's outside of the car.
