Acrylic enamel orange peel/dry spray - reshoot or cut n buff?
Discussion in 'The Hokey Ass Message Board' started by oldrelics, Sep 20, 2013.
  1. oldrelics
    oldrelics
    from Calgary
    I finished spraying my '41 Ford cab, and after a couple of hours I noticed a dry spot on my dash. I knew I had coated it a couple times and was really surprised to see it dry. When should I try to cut n buff? Or when should I recoat it? Acrylic enamel with hardener.
  2. brigrat
    brigrat
    from Wa.St.
    I would cut lightly and buff BUT with only 2 coats I say reshoot, nothing to loose. The longer you wait the better to a point....................
  3. 5559
    5559
    from tn
    800-1000 wet then buff
  4. slammed
    slammed
    How much did you lay on it? If in doubt, lightly wet sand it smooth re-coat it and use more lighting to really see what your laying down for coverage.
  5. F&J
    F&J
    did you paint today or yesterday? If yes, it may settle even more elsewhere. I'd wait to see if any more places need work.
  6. brandon
    brandon
    block it with 800 and hit it with a couple coats of paint with a little more reducer and hardner....its worked for me in the past with centari
  7. oldrelics
    oldrelics
    from Calgary
    I sprayed it today. Product info says spray 8:1 and reducer is optional(medium and it was 22-23 deg celsius today) up to a quart per gallon. So I mixed 8:1:2 but it still seemed pretty thick, my 1.4 tip didn't really like it so I used my 1.8 and seemed ok. Seems a little weird why I can't reduce it more.....
  8. ibxledphoot
    ibxledphoot
    you will have to sand it smooth to recoat it anyway or your peel will still show so might as well attempt to sand n buff first.
  9. TR Waters
    TR Waters
    from Vermont
    I would wait a couple weeks.
