Features Doing Falcons Right
Discussion in 'The Hokey Ass Message Board' started by falconizer_62, Jul 23, 2008.
  1. gimpyshotrods
    gimpyshotrods
    All this talk of radiatiors gave me cause to go check mine. Not sure how it is possible, but the date stamped in mine, coincides with the week that my '60 left the San Jose (Milpitas) factory. Still clean inside, still runs cool. Nuts.
  2. nash510
    nash510
    from Vista, CA
  3. Just hadda replace mine. Date stamped 10/60 for my car built on 10/25/60.
    BTW, seems all aftermarket rads for my Falcon are the same (which is to says there's only one). It's a three row A/T rad, fits a bit tight, but it fits and works better than necessary. The fan now struggles to pull enough air through the core at idle (450 rpm), so I get a bit of temp rise at idle. All is good above that speed. Gona build me a shroud, when I get the time (and get outta this cast!)
    Cosmo
  4. Gimpy , our '60 was also ***embled at SJ, whats the build date on your drivers door tag ?
  5. gimpyshotrods
    gimpyshotrods
    02H. August 2, 1960.
  6. Ours is 22H , 20 days later . Would've been hard case if they'd left the plant the same day. Do you know where yours was sold new ? Ours was Redlands Ca
  7. gimpyshotrods
    gimpyshotrods
    Dervin Ford, Novato, CA. Still has the license plate frame from the dealer on it.
  8. Kustom.Falcon
    Kustom.Falcon
  9. falconizer_62
    falconizer_62
    I have been working on a radiator, core support fan shroud deal for about the past 4 weeks. Mine is not for a v8, but rather a much longer 6, which would put limits on me that you V8 guys would not necessarily have to face. The motor is so long, that even stripped the only way I could get it in the car was to lift the car over the engine and have all of the front suspension and crossmember removed. This necessitated me needing to cut the core support, which you probably wouldn't need to do if you're running a v8. Once I cut the core support the structural integrity of the front was compromised, so it also had to have strength, which I wouldn't recommend doing just to install a v8.
    All that being said, if any of the above information would be helpful to any of you, let me know and I will go shoot some pictures of it. Peace and good luck :)
  10. falconizer_62
    falconizer_62
    Changed out the exhaust manifolds today , fitted up all the new gl*** runs and cat whiskers to the doors , new pan gasket and filter in the trans and made a start on the exhaust sytem. Not a bad days work I guess .
    [​IMG][/URL][/IMG]
    [​IMG][/URL][/IMG]
    [​IMG][/URL][/IMG]
  12. falconizer_62
    falconizer_62
    Not at all! Thanks for the motivation. Fantastic looking car.
  13. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    We sure do have a lot of white Falcons in this thread and I like 'em!
    Nice work, four-six.
    Like some other dudes here, I'm starting to get all warm n' fuzzy about Mini Lite wheels, too. If I could afford a set...
  14. gimpyshotrods
    gimpyshotrods
    Konig Rewind. Summit has them.
  15. Evilfalcon1961
    Evilfalcon1961
    from Ma
  16. Burnt out , thanks for the kind words. I managed to find the Mini-Lites secondhand here, they are early ROH ones in 15x7 . I would have no problem with keeping a look out for another set for yourself or anyone else here who'd like some. There have been folks here on the HAMB ( like yourself ) who have helped me out with parts/leads on parts so if I can repay the favor/s that would be great!
    Gimpy, what are a set of the Konigs worth in the USA? Here in NZ we can buy new Mini-lite style wheels for approx $1600- NZD a set ( approx $1300- USD) in 15" and 16" .
  17. Fingers
    Fingers
  18. NeonGodzilla
    NeonGodzilla
    Revernd Paul
  19. Russ V.
    Russ V.
    Try this....:D
  20. Leon Sandcastle
    Leon Sandcastle
    That's what happens when I let the wife drive the car!
  21. gimpyshotrods
    gimpyshotrods
    Konig Rewind wheels can be had, new, each, for $120 (15x7) to $140 (16x7) USD, plus shipping.
  22. nash510
    nash510
    from Vista, CA
  23. falconizer_62
    falconizer_62
    Nice exhaust work :). It'll be interesting to see how it sounds
  24. 63comet
    63comet
    That's pretty impressive. I want to figure out eventual a way to dump my exhaust in a similar location. I like that '60s road course look alot.
  25. nash510
    nash510
    from Vista, CA
    Thanks. Despite the muffler and resonator it's still very loud - kind of race car-ish - especially with no interior.
  26. jchav62
    jchav62
    We're not in Kansas anymore!!
  27. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Decent price- I'm only seein' 4 lug wheels....
  28. falconizer_62
    falconizer_62
    Nothin' wrong with that!
  29. Alfster
    Alfster
    Looking good Rod. I will have to come around and check it out.
    Mummy must be happy.
  30. falconizer_62
    falconizer_62
    Here is the radiator and core support and fan shroud. I got a good chance to take some pics today.
