How to Lower my 65' Ford F100?
Discussion in 'The Hokey Ass Message Board' started by dfetterolf, Sep 21, 2013.
  1. dfetterolf
    dfetterolf
    I want to lower my 1965 Ford F100 (twin I Beams). Any suggestions?
  2. mattrod68
    mattrod68
    djm beams, the only way.
  3. RMR&C
    RMR&C
    from NW Montana
    Yeah, drop beams. Only other option is to yank the whole front end and replace it with something else.
  4. Texas62
    Texas62
    from Tejas
  5. dfetterolf
    dfetterolf
    Thanks for the responses. Just as I suspected, either drop I beams or sub-frame it. Thanks
  6. derbydad276
    derbydad276
    crown vic clip bolts in!
  7. plymouth1952
    plymouth1952
    The crown Vic is the way to go its alittle more then a bolt in. theres some links on you tube try 1969 f-100 swap
  8. old soul
    old soul
    from oswego NY
    You could also just go under your truck with a torch and just cherry red the axel close to the wheel. You will see the truck start to drop. But don't go to far. slow and easy. also helps if you put wood blocks under the frame so it cant go to far.
  9. brokenspoke
    brokenspoke
    I hope your kidding
  10. HOTRODPRIMER
    HOTRODPRIMER
    Obviously,you don't know anything about twin I beams!:eek:
    I hope the OP doesn't try this. HRP
  11. dfetterolf
    dfetterolf
    Don't worry, I'm not dumb enough to use the torch "trick".
    Sent from my SCH-I535 using H.A.M.B. mobile app
  12. old soul
    old soul
    from oswego NY
