Projects crminal coupe, an attempt at a 31 A build
Discussion in 'The Hokey Ass Message Board' started by crminal, Aug 13, 2013.
  1. crminal
    crminal
    So here it is. After 1 year of building my very first hot rod, I am starting my build thread. Really did not know know what I was doing but with the vast knowledge of the Hamb, it is moving along. I have a 29 coupe which I am leaving as a hopped up survivor car, but for this 31 coupe, "wanted a V8". Started thinking I'd use a nice 302 that I had built for my econoline project, but it felt too modern for this build. Seriously love flattys but wanted something a little more advanced. So.....292 Yblock it is!
    The car came to me through my brother in law who knew of a co-worker trying to sell the old family car (his grandfathers). He even had the original ***le from 1932. Thanks to my brother in law or this would not have happened.
    Here she is when she got home.
    Stripped her down
    Then some more
    And ended up with this beauty! And a frame with a good CA VIN!
    Decided to spend the money and have the frame sandblasted... worth every penny!
    Bought a new So Ca. spring, shackles, axle and spindles off Craigslist. Really kind of scary at this point because I really don't want to build a catalog car and it's so easy to get in that groove. Want to stay with using as many old parts as possible.
    lothiandon1940 likes this.
  2. crminal
    crminal
    I was really trying to keep this on a budget that did not get out of hand. I sold off the parts I would not need and started on my build fund.
    Again, the hamb was a good source for buying old parts.
    So, I'll start with the rear. Want to drop it about 3" and decide that it will be simpler to use coil overs in the rear. Never having done this before, it seems like a Speedway rear frame kit will be the way to go.
    Wrong! about 3" too narrow for a stock frame. I'm figuring it out about now that I'll be making up my own parts whenever possible.
    So, locate the rear axle (narrowed 9" Ford with Currie axles bought from the hamb) and build my own rear frame piece.
    Jig up the axle mounts for the Pete&Jakes ladder bar kit (Alliance membership paying off)
  3. pila38
    pila38
    Lookin' nice man. Keep it up.
  4. dad-bud
    dad-bud
    Keep posting criminal - it looks like you've started with a great coupe there.
    Thanks.
  5. crminal
    crminal
    Moving right along.....
    Notched the frame for axle travel, plated the frame and rear crossmember, and installed the panhard bar.
    Made up some nifty upper shock mounts
  6. jim henderson
    jim henderson
  7. MATACONCEPTS
    MATACONCEPTS
    there it is. Wheres the Y-Block?
  8. crminal
    crminal
    Oh, it's hiding around here somewhere...... ImageUploadedByH.A.M.B.1376420558.966546.jpg
  9. crminal
    crminal
    So along the way, I find this 292 on the Hamb. A couple of cool old guys pulled it out of a '59 truck in running condition and it was so complete, I drove to Yuma to get it. Called McTim with the vital numbers and bought it. Btw, McTim has been more helpful than he knows! ImageUploadedByH.A.M.B.1376422691.432456.jpg
    But how will that fit? After lamenting about cutting the firewall and such, I realize that this is hot rod building. If I want to stretch the frame 3 1/2" and not run a hood, so be it. I come up with this hair brain idea!
    (I hope so at least ;~)
    Move the crossmember forward 3 1/2".
    So I drill the rivets and remove the xmember.
    Mark and cut the frame, leaving the top flange
    Sandwiched the upper flange between to pcs. of heavy steel and clamped until flat. Tacked the gaps in position and welded.
    Made a backing piece, fitted to the inside, clamped the heck out of it and welded it in
    Stay tuned....
    And thanks to those posting comments!
  10. crminal
    crminal
    Hey guys, trying to keep up with this! Here goes...
    When I moved the crossmember forward, I had done all the figuring by measurement and not with the body in place. Now it was time to set the body on and hope it all fit. As mentioned, I did not want a cut firewall and I had to run a mechanical fan.
    I start cutting the portion of the subframe where the frame had a kick-up. The body had some rust just above the axles at the body edge. So, it gets cut out along with some of the floor panels.
    I bought some new inner fender panels from a Hamber and will replace when the time comes.
    Well, Its Mothers day and there are a bunch of guys hanging around wanting to do something constructive, so...
    The body goes on!
    IMG_1590.JPG and the engines goes in.
    And a cigar for my hard work:p
    This might just work:eek:
  11. chevy54man
    chevy54man
    from NC
    Great work man, love your coupe!
  12. nunattax
    nunattax
  13. crminal
    crminal
    Thanks Guys! Appreciated
    I'll post some more photos of how it all fit in there soon.
  14. crminal
    crminal
    ImageUploadedByH.A.M.B.1376940278.739626.jpg ImageUploadedByH.A.M.B.1376940316.512987.jpg Looks like Ford allowed for that dizzy to fit right in there!
    ImageUploadedByH.A.M.B.1376940407.230421.jpg if you look up where the tail shaft is compared to the crossmember, looks like a mod needs to happen there.
    ImageUploadedByH.A.M.B.1376940542.231615.jpg too close for me. What kind of clearance do we like to have here?
  15. crminal
    crminal
    Also, I trimmed the stock crossmember to allow for the trans. I'll figure all that out later.
    Now, got to get the motor lined up and in place.
    Motor mounts, bought the ready made bases and rubber, but need to make the upper. Using some 3/16" material, started drawing and cutting.
    ImageUploadedByH.A.M.B.1377608052.895737.jpg ImageUploadedByH.A.M.B.1377608163.580764.jpg
    Welding
    Welded some tabs on the frame mounts so I could clamp them to the frame
    I'm welding this inside the frame rail and will box around them.
    And like it or leave it, this is what I ended up with...
  16. crminal
    crminal
    Thanks Bib, appreciated.
    So with the engine in place, time to start working around some issues. One is the lack of space to be taken up by the steering, oil filter and exhaust.
    I really want to use these manifolds
    and a modified F1 box
  17. Great stuff. Good to see a Ford engine with the dizzy at the right end, haha. Jk
  18. Great job so far! I'm sorry I didn't check in here earlier. Great fab work, I like what you've done. Keep it up! :)
  19. Not sure if there is enough room to put a remote adapter on for the oil filter.
  20. There is something headed his way that may work. We'll see.
  21. Looking forward to it. I'm stuffing an Olds 394 in and A frame so I'm having some of the same issues.
  22. crminal
    crminal
    Well, I gotta say that McTim is a one of a kind good guy. Sent me this 90* adapter to try and solve my issue with the filter.
    Got a pretty damned good fit and missed the steering box but pointed it right into my motor mount :mad:
    Unfortunately, the way it is made, I can't clock it to between 7-8 o'clock where it may have fit.
    I'm going to try the Ford racing 90* adapter and see what I get.
    Thanks again Tim!
  23. frankie3555
    frankie3555
    from Leeds, Al
    If you run out of choices..I used this one from Canton. It can rotate 360 degrees and will NOT leak. They are a little pricey but if you look around you can get one for about $80. It may not be old school friendly but you could disguise it somehow.[​IMG]
  24. crminal
    crminal
    Good choice. I actually talked to Bob at Canton this afternoon about that part. If the Ford "all in one" style doesn't work, that is what I will use. Trying to avoid lines if possible. Thanks for the tip!
  25. Damn!!!
  26. crminal
    crminal
    And we have success!
    32owner likes this.
  27. Yikes. Lube it up and push it in. That's a tight fit. Good score!
