Technical Stock 1932 Ford 3 window rockers, Need close up pics, Help!
Discussion in 'Traditional Hot Rods' started by Sledge, Sep 24, 2013.
  1. Sledge
    Sledge
    from Nor Cal
    Hey guys, Im trying to install some aftermarket rockers on an original 32 3 window body. There is not much of the original rocker left so Im trying to find some close up images to get these as accurate as possible. Even a brookville would be fine because im sure they are very close to original. Thanks for the help!
  2. Sledge
    Sledge
    from Nor Cal
    This is where im at now. Just trying to figure out how to connect the old with the new. don't know if it's supposed to have the curve up then make a piece over or if I should just cut that off and go strait to the subrail. I've found a few pics online but they are too small so I cant tell exactly how this should be.
  3. willysguy
    willysguy
    from Canada
    Here's how I did mine.............
    Looks like you're missing a bit of material from the raised lip tp the repop rockers edge. They are tricky. Hope this helps ya out. Duane
  4. Sledge
    Sledge
    from Nor Cal
    That helps a lot. Thanks Duane!
  5. couverkid
    couverkid
    Kevin I will email you pictures of mine. They are original never replaced.
  6. couverkid
    couverkid
    Here are my originals.
  7. Sledge
    Sledge
    from Nor Cal
    Thanks couverkid!
  8. big creep
    big creep
