Technical Anglia spindle ?
Discussion in 'Traditional Hot Rods' started by Louie S., Sep 24, 2013.
  1. Louie S.
    Louie S.
    Does anyone make an anglia spindle that will fit on a ford axle? I have a speedway tube axle at the moment, but will be switching to a ford axle when my spindle mounts show up.
  2. Pete Eastwood
    Pete Eastwood
    from california
    What is your end goal ?
    If you are looking to put Anglia spindle mount wheels on a car that has ford spindles,
    you can re-machine the ford spindle spud to take the Anglia bearings. You'll have a tough time getting an Anglia spindle to fit a ford axle.
  3. Louie S.
    Louie S.
    Iam putting spindle mounts on, I am not sure of the Anglia dimensions. I don't mind machining these down if I could get the specs.
  4. brandon
    brandon
    depending on the wheel , you can easily use a spindle mount wheel for a strange strut on a ford spindle....just saying..:D machining the spindle is about the only way you get the Anglia bearings to work on a ford spindle...
  5. Laser Dave
    Laser Dave
    Brandon
    What is required if anything to put a strange strut wheel on a ford spindle?? Am looking to run spindle mounts in the near future. Thank you
  6. brandon
    brandon
    its is pretty much the same as running a late model disk brake kit...we used a disk brake adapter bushing on the back side ...the piece that looks sorta like a top hat. have to check what bearing on the outer. I have a set of strange strut hubs at my buddy's machine shop that we were making brake parts for. but figure the strange strut is a copy of a 70's Camaro spindle spud.
  7. I thought Anglia was Ford. So Anglia spindle is already on a Ford axle.
  8. Anyway, here is the anglia dimensions.
  9. Louie S.
    Louie S.
    Thanks for the dimensions.
  10. dreracecar
    dreracecar
    from so-cal
    So there is no confusion the inner bearing is 25mm ID
  11. Larry T
    Larry T
    You might look at what "The Ch***is Shop" sells (if they're still around). They have an Anglia speced 4130 spindle piece (spud??) that you might weld into a modified Ford spindle.
  12. hotroddon
    hotroddon
    Which is .984" as shown above :D
  13. brandon
    brandon
    stop it man....your talkin crazy...:eek::D
  14. Larry T
    Larry T
    What else is new? :D
  15. dreracecar
    dreracecar
    from so-cal
    Have you ever tried asking for a .984 ID bearing??:eek:
  16. Larry T
    Larry T
    Just looked and my old dogeared BCA Quick Reference Specification Manual lists both a .9842 and a .9843 (25mm) bearing bore size.
    Here's the specs, bearing and seal numbers posted in 2006.
    http://www.jalopyjournal.com/forum/showthread.php?t=98091
  17. I wonder if .0001(one ten-thousandth) will make a difference?;)
  18. Larry T
    Larry T
    Not around my place it won't, but it is a different listing.
  19. Bearing Burner
    Bearing Burner
    from W. MA
    Ford(U.S.) king pins are larger and the boss longer than Engilsh (Anglia Ford) . Therefor the US spindle could be turned,shortened and rethread,but nor easily. Spindle mounted Wheels were avaiable with U.S. Ford Bearings. Fairly common at racer flea markets.
