1962 country sedan windshield
Discussion in 'The Hokey Ass Message Board' started by mercury1, Sep 13, 2013.
  1. mercury1
    mercury1
    from Milton WA
    I am having trouble sourcing a windshiel and the seal for my 62 country sedan. I thought that the window and seal would be the same as the galaxie sedan or the four doors but apparently this is not the case. Are they the same? Can anyone point me in the direction of a supplier? It is starting to get wet in Washington state so I need to get this seal replaced.
  2. czuch
    czuch
    from vail az
    Mac's for the seal, I'll bet.
    I siliconed the seal on my Galaxie to stop leaks for now.
  3. Dexter The Dog
    Dexter The Dog
    Don't use silicone on car windows. Mulco makes a thermoplastic called Flexstra or Flex 9000. Stronger tensile strength than adhesive strength which means it removes clean when needed.
    Like - when you make a mess!
    The clear stays crystal clear not cloudy like silicone. It also has something like a 22 yr UV rating.
    BUT - not compatible with silicone so don't put it anywhere where there may be residue from silicone.
    It's also not good for filling holes like silicone. Only good for running beads along seams.
    Once you're used to using it you can pull a bead that looks like it was done by a robot.
  4. junkyardjeff
    junkyardjeff
    It should be the same as a sedan.
  5. sprayberry1
    sprayberry1
  6. big M
    big M
    These windshields all interchange, and, therefore use the same gaskets-
    '62 Ford wagon and Galaxie, except convertible
    '63 Ford except Convertible, T-bird, and 2-door fastback HT.
    '64 Ford 2 and 4 door sedan and wagon
    Mercury '62-'63 wagon and Monterey except convertible
    Mercury '64 except convertible and fastback HT
    ---John
  7. pride63
    pride63
  8. FiddyFour
    FiddyFour
    steele rubber should have the gasket you're looking for...
  9. mercury1
    mercury1
    from Milton WA
    Thanks everyone! I have a window on the way! Much appreciated.
