CHOKE What do you prefer???
Discussion in 'The Hokey Ass Message Board' started by Kensey, Sep 27, 2013.
  1. Kensey
    Kensey
    from Pittsburgh
    I need to add a choke to my rochester 2 barrel. It's on a buick nailhead 364.
    Now that the weather is cooling down it's a ***** to start.
    What do you prefer?
    -Electronic choke
    -Spring with heat tube to manifold
    -One of those stove pipe units that rad clamps to the manifold
    Thoughts?
  2. manual choke.....i like to be in control of when the choke is on/off myself
  3. HOTRODPRIMER
    HOTRODPRIMER
  4. flathead4d
    flathead4d
  5. themoose
    themoose
    Manual for me
  6. Lowdownfab
    Lowdownfab
    Living in Florida I don't use a choke a whole lot, but def prefer a manual choke. I like simplicity, less stuff to go wrong.
  7. SanDiegoHighwayman
    SanDiegoHighwayman
    ditto
  8. HOTRODSURFER
    HOTRODSURFER
    from HATBORO,PA
    same here
  9. hankthebigdog
    hankthebigdog
    from oklahoma
    I am with the rest here in OK. manual
  10. Post Apocalyptic Kustoms
    from Outside
    Manual choke or NO choke. The ONLY two options.
  11. theHIGHLANDER
    theHIGHLANDER
    Nothing wrong with an automatic choke if you hook it up right. They can last for 100,000 miles. Knowing how rich to set it up and when to kick it down are all you have to worry about. Packard had automatic chokes in 32-3-4 and beyond. Never a lick of trouble once set correctly.
  12. upspirate
    upspirate
    Living in Fla I have no problem with no choke as long as the engine is tuned properly.
    When I do have a choke, I like manual
  13. Kensey
    Kensey
    from Pittsburgh
    Interesting, not the response I expected.
    So riddle me this, pretty much only closed when starting, once warmed up keep it open. Half way before it's totally warm on a cold day. Memories of my mom's camera!
  14. 1971BB427
    1971BB427
    from Oregon
    Manual on both my hotrods. I only use it to fire up, and then it gets shut off as soon as it fires.
  15. willys1
    willys1
    from South Ga
    ^^ same here....manual..simple
  16. Abomb
    Abomb
    The two handed full frontal, if available...the rear naked choke if the receipient happens to be a bit of a wiggler....:D
  17. Kensey
    Kensey
    from Pittsburgh
    Was wondering how long it would take this post to get nasty. Though I appreciate potty humor as much as the next fellow s***bag.
  18. bgaro
    bgaro
    manuel for me as well. those rochester 2gs, the choke swings up and down not front to back, originally they used a spring gizmo off the manifold. i'm trying to find a different set up to use cable choke. any ideas?
  19. rouye56wingnut
    rouye56wingnut
    from mn.
    That carb is about as dirt simple as it gets . I dont know why you would change anything but a new choke spring and let it go .Seems a big waste of time to me to have to run that ugly *** cable through the firewall and hog holes in your dash for the bracket , on top of having to spend about the same money as you would on the original spring .
  20. bgaro
    bgaro
    read post #2
  21. rouye56wingnut
    rouye56wingnut
    from mn.
    Gregs just old and too lazy to bend over and set the choke :D .
    I just dont get putting a band-aid in place of a perfectly good working unit .
  22. 1971BB427
    1971BB427
    from Oregon
    Ugly cable and holes for a bracket? A traditional spring wound cable housing (not black plastic!) is small and clean. A single hole to slip the choke handle through is all that's needed, not multiple holes and an ugly bracket.
    These are what I usually go with:
  23. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    I'm gonna' agree with Highlander- there's nothing wrong with an automatic choke as long as it's adjusted properly for opening and fast idle.
    If I was the only person that was driving my old car I'd prolly go with a manual choke.....
    The Missus likes to drive the car occasionally n' she has a history of "forgetting" to push choke/enrichner knobs back in....
    I once had to drive over the bridge into Maryland ta' put a coup'la plugs in her Dyna Glide because she "forgot" to turn the choke off during her commute to work....
    I'm sure that's not the case for you guys.
  24. 63comet
    63comet
    That wasn't potty humor, violent fighting humor.
  25. fsae0607
    fsae0607
    Yeah, buddy!
    Running manual on my 61. Easy to use.
  26. sunbeam
    sunbeam
    I like to find the manual chokes use on Ford couriers. If you forgot it would pop back in, in about a minute
  27. tfeverfred
    tfeverfred
    If I had to use one, it would be manual.
