Saving a 32 Ford Body
Discussion in 'The Hokey Ass Message Board' started by rcnut223, Dec 11, 2011.
  1. staleg
    staleg
    Good Luck! You're in for a lot of work, but it will be worth it in the end. And by then you will be an expert on 32 Ford, 5 window bodies.
    My p***ion is for the 33-34 and this is what I started With in 2002:
    Got the plates on this august:
    Notice the frame jig. It's home made. I strongly recommends you to make one, too. I wouldn't been able to get the body and frame straight it without it.
    kidcampbell71 likes this.
  2. jdownunder
    jdownunder
    sorry mate i wasn't very clear im not building a 32
    trying to piece together a 5w coupe out of 29 chrysler pickup
    and 30 ford roadster rear quarters just meant its a jigsaw as well
    your roadster looks really nice
  3. staleg
    staleg
    Me to be sorry. My answer was ment for rcnut223 and his 32 build.
    But it should fit all that start working on real bad car bodys. Just replace the "32 Ford ...etc" with your car make!
  4. bambbrose
    bambbrose
    from So. Utah
    I would only choose a color other than black if you can live with the decision.
    If you are going to wish you had black, but know that you compromised on that decision to save a few weeks/months labor, then it will eat at you.
    My $0.02
    Progress is still amazing. I can't believe how straight she looks based on what you started with.
  5. rcnut223
    rcnut223
    from wisconsin
    Took the day off to try and get the car in primer. Suppose to rain this weekend and aim getting some surface rust
    The epoxy i am using is black , this will get me an idea of the look
    One door is also about ready so it will get shot as well
  6. rcnut223
    rcnut223
    from wisconsin
    As Brandon (Jalopykid) stated, tThe roadster I show is from Bruce's rod shop in spring Texas. I took the picture when I visited.
    You might try and contact Danny on the color , it is his dad's roadster.
    The other green is a picture i found on the web, really like that one too!.
    Here is a bronco green 1970, love this color in person took a shot a recent local car show.
    Can't figure out the maroon color , could use some help here.
  7. rcnut223
    rcnut223
    from wisconsin
    Staleg
    That roadster looks killer!!!Did you make the back half? Tell us more!!!!
    Your right on the jig. I built my car on the 32 frame that was leveled front to rear and side to side to provide a foundation. Without this the build would not have happened.
  8. rcnut223
    rcnut223
    from wisconsin
    jdownunder
    good luck with your build , hope you have lot's of time on your hands.
    hint....I would not do this again!!! i'd spend the money and buy good body the heck with the accomplishment thing :)
  9. rcnut223
    rcnut223
    from wisconsin
    I hear ya cavman, bambrose & Martin
    I've owned a couple black cars, when clean you can't beat it. But after a few miles and years everything little chips and scratch starts to show, That really starting to weigh on me.
    Lot's of sand where i live , on the roads and blowing around.
    Martin
    Yup, lots a work. Lost 10 pounds sanding so far :)
  10. alchemy
    alchemy
    The green on that channelled coupe and the Bronco is kinda trendy right now. Lots of cars using the subdued green/gray paint. I bet it will be played out in a year or two.
    The red on the coupe is very close to a Ford Medium Red from the early 80's. Look towards the end of Geoking's thread about his coupe and he shows the code. It's one of my all-time favorites.
  11. staleg
    staleg
    rcnut233: Thank's for the kind words. I admit that I recieved some help with the back. I made plywood templates based on a fibergl*** car to a friend of mine, and then left the body to an english wheel expert. He rolled the two missing areas and I welded them on.
    Later I used the same jig to make a "dolly", too:
    I had heard that the frame wasn't stout enough to support the body during heavy bodywork.
  12. woodbutcher
    woodbutcher
    :D Hi folks.Some of the lighter greens look similar to the green that was OE on 53 Stude coupes.
    Good luck.Have fun.Be safe.
    Leo
  13. rcnut223
    rcnut223
    from wisconsin
    Well I finally got this thing in primer! Nice to have it in one color.
  14. rcnut223
    rcnut223
    from wisconsin
    Staleg
    Man that is really cool!
  15. The37Kid
    The37Kid
    Coupe looks great in primer, now the real sanding starts. Bob
  16. greaser
    greaser
    Just an amazing job! That little coupe is sooo sweet! Great milestone.
  17. staleg
    staleg
    Looks like av very nice job you have done on that body!
  18. 4psi
    4psi
    Great work!!! I am glad to see it in one color!! Keep up the hard work and determination!
    -Charlie
  19. 94hoghead
    94hoghead
    Incredible work......
  20. HOTRODPRIMER
    HOTRODPRIMER
    Amazing work! HRP
  21. flatford39
    flatford39
    Paint it gloss black. That body and your workmanship is incredible. There's only a few good days left this year to paint outside so I would concentrate on finish sanding and applying color in the spring. Thank you for this thread. It has been appreciated.
  22. Pewsplace
    Pewsplace
    WHEW! This has been some ride. Your end result is something to be proud of. Thanks.
  23. rcnut223
    rcnut223
    from wisconsin
    Thanks guys certainly feels good, and yes a big milestone!!
    Thought I would take a couple shots of some of the more heavily worked areas of the car and show how they turned out. Note I have 2 coats of primer on the body work at this time.
    kidcampbell71 and mgtstumpy like this.
  24. rcnut223
    rcnut223
    from wisconsin
    During the bondo work I used dura blocks to sand the flat portions of the car. The 32 has more curves than any car I had worked on...
    As a result I had to get creative , here are some of the tools I used to sand the various shapes.
    Probably the most useful was the small foam blocks wrapped with sand paper , followed by the plastic motel door cards.
    I also folded paper over and cut the shape you see. Worked really well on the body lines around the windows
    Now I need to get the doors done!!
  25. paco
    paco
    from Atlanta
    You need to ad a "before" shot so folks can REALLY see the trials & tribulations you went through to get the car into the shape it's in today.
    I can only say: UNBELIEVABLE!
  26. Gary Addcox
    Gary Addcox
    O. J., what makes it SPECIAL is the year of make, NINETEEN HUNDRED AND THIRTY FREAKING TWO. Those are the only ones people will go the ends of the earth to save. Now, I am not prejudice, since I only own one. That will be a really neat deal when completed. Good luck, Bud.
  27. ric
    ric
    Incredible job, if I hadn't followed this thread I would not have believed it is the same car. You are a real talented craftsman.
  28. Von MoPar
    Von MoPar
    from Australia
  29. rcnut223
    rcnut223
    from wisconsin
    Paco
    great idea...here's a couple examples
  30. rcnut223
    rcnut223
    from wisconsin
    And another...
