Features Econoline Madness Who's got one?
Discussion in 'The Hokey Ass Message Board' started by kornfedlifer, Apr 25, 2007.
  1. Joey Anchors
    Joey Anchors
  2. econolineherb
    econolineherb
    Lights are kool . Bumpers not so much . The ICC put them on many vans and pickups .
  3. ccain
    ccain
    Hey gang.
    I'm just finally working out all the old bugs on my newly acquired '66 Econoline left behind by the string of previous monkey wrench wielding idiot owners.
    Since I got it, my first priority was to make it safe and dependable. Now that I'm on the downhill side of that, the only thing that really bugs me about the van is the nose. It was beat in pretty bad and then some dillweed decided to beat out the dents from the inside with what looks to be a ballpeen hammer.
    Does anyone have any ideas where to start? I mean, I've done my share of bodywork in my day and have even welded in new rear corners on this van. BUT, I've not had much luck in the past getting extremely tweaked metal straight. If there is one thing I'm dead set on is that there will NOT be a ton of bondo in this beast when all is said and done.
    Do any of you sheetmetal Guru's have any pointers? Thanks!
    droppedstepside likes this.
  4. elba
    elba
    After completely overhauling the dreivetrain and engine, I put new wheels and tires on it and drove it in the back 40 today . It will be ready for paint in a few weeks.
  5. porkshop
    porkshop
    from Clovis Ca
    I need a 61 to 64 manual 3speed trans if anybody has one. Ive posted it in the wanted section also.
  6. Straight Axle Steve
    Straight Axle Steve
    I have one. I'm in Michigan though. I can ship it business to business pretty cheap. IM me if interested.
  7. econolineherb
    econolineherb
    Vic has one in Ca.
  8. Hellfish
    Hellfish
    FWIW, I think that any '61-67 3-speed trans will work as long as it came from a 144 or 170 Econoline. The 240 trans is different, so make sure you have the right one before you ship it!
  9. porkshop
    porkshop
    from Clovis Ca
    Not being a smart ***, but it might help if I knew who Vic was. I have a line on one in Georgia guys checking on shipping. THANKS Guys:rolleyes:
  10. second fiddle
    second fiddle
    Please....no on the bumpers!
  11. econolineherb
    econolineherb
    Vic is on the Econoline groups . There's alot of people on the groups with parts and are in just about every state . Canada and over sea . There might be someone close to you to help .
  12. Muttley
    Muttley
    Whats the problem.......your crystal ball in the shop or something? :D ;)
  13. go-twichy
    go-twichy
    most people that have a econoline know who vic is. he's been into econoline's and the van scene from the beginning.
  14. Hellfish
    Hellfish
    He goes by "Vic in CA" on the Econoline/van forums.
  15. big57daddy
    big57daddy
    Harrison:
    is this what you are looking for? If so, PM me.
    It's a little crusty, but everything is there and it should clean up OK.
    cheers, Ray
  16. can somebody get a hold of "Vic in Ca" for me and see if he can get me a decent oil pan for a '65 ford falcon econoline van ,240 ,6 cyl.motor
    or anybody got one for sale.....
  17. econolineherb
    econolineherb
    vic is at .
    vlafountain@so cal.rr remove space .
    Like i said Join the groups .
  18. johnnybentwrench
    johnnybentwrench
    I picked up extra corner windows today
  19. Joe Bassett
    Joe Bassett
    from usa
    I have a 1964 5 window drive it every day 170 6 4 speed Joe in Fl
  20. wisconsinjimmy
    wisconsinjimmy
  21. Harrison
    Harrison
    I have a 200 in my '65 Econoline panel van. Before I start spending $$$ on it, I was wondering if a 300 swap is possible/would be a better choice.
    Hate to dump $$$ into the 200 when dumping it into a 300 makes more sense.
    TIA, JH
  22. wisconsinjimmy
    wisconsinjimmy
    A 300 or a 240 will go in but not the injected 300 as it is to tall
  23. Hellfish
    Hellfish
    It's just as much work to drop in a 300 as it is to drop in a 289/302 and slightly less work than dropping in a 351.
    Do a search. I posted all the details of Econoline engine swapping a few years ago. In a nutshell, if you have a 200 you're going to need a transmission, driveshaft, rear end, and radiator just to get started. Then you're going to need to set up a new throttle system and modify your motor mounts. Pretty much nothing from the small 6 (144/170/200) van will work with a big 6 (240/300) or v8 swap. It can be done, and it's not that hard if you have the parts. You'll probably be a lot happier with more power... but upgrade your brakes, too. :)
  24. wisconsinjimmy
    wisconsinjimmy
    Hellfish is correct on every point, if you have the 65 Econo then you should have the removable mount/Xmember which will have to be modified and Vic in CA does a bang up job jig welding the mounts and all you have to do is bolt it up and drop in the 302. Go to Yahoo Groups and look up econosrus and join the group also oldeconolines is another group .
  25. econopoor
    econopoor
    from Jackson TN
    Something looks familiar here!! Good to see you Terry.
    Duane in Tennessee
  26. go-twichy
    go-twichy
    if it was me, I wouldn't bother with the sixes, go for the 302, it fits nice.[​IMG]
  27. Harrison
    Harrison
    Thanks guys. This is the info I needed. I'm staying pretty "stock" on this one. It's not my only ride and it'll rarely ever get outside of town. I think sticking with my 200 is my best bet.
    Let the $$$ dumping commence!
    JH
  28. Harrison
    Harrison
    Anyone know the stock backspacing on the wheels of a '65?
    TIA, JH
  29. here's mine......so far I've wire brushed the inside then epoxy primed it, replaced lower door skins and door bottoms,fixed rot in floor, replaced windshield rubber, new master cylinder,cleaned gas tank, replaced sending unit float,new horn relay, ****on and spring.2nd hand headlight switch,used thermostat housing, new thermostat,added a overflow tank,tune up, 4 new tires,..you get it the drift, the usual stuff. Most of the bugs are worked out with exception as to where the oil is leaking from.....
    oh yea ,she's a 1965 ford falcon econoline van....you can see the falcon name on the p***enger's door....
  30. Harrison
    Harrison
    Solid looking van!
    What kinda carburetor is that?
    JH
