Thanks man I am about to redo the top 4 link bars and cross member then when that's done it really will be on to the motor install. If they feel the need to delete my build thread it's their choice I hope at some point it gets moved to traditional styled hot rods and customs. Jake
Start of the crossmember the curve will replace the top part top bars will be relocated to the top of the pumpkin and will be triangulated down to the top of the frame rails.should get it done this weekend. Jake
Started with a center cut and cut every 1 inch then bent it till the gaps were touching then went back with a 4 in grinder with a cut off wheel and re opened up the gaps then bent it shut agine. Jake
Rear top bars and cross redone still need to adjust the angle at ride height and cut off the other axle tabs and grind down the curve where it's welded back together. Jake
Tail gate sorry pics are ****py phone pics there is a third color that does not show up in the pics on the tail gate and hood it's a teal color close to the trucks paint color. Jake
Man this is a kick *** truck. I just sold my 61 unibody to find my 54 bel air. I'm subscribing to this one. Posted using the Full Custom H.A.M.B. App!
I keep putting off taking it back apart so I can put it up on stands and mocking up the motor and trans in it lol. Jake
Got the last of the factory crossmembers out and the rest of the frame boxed.Now time to get the drive shaft shortened and tunnel the torque box and some floor bracing ect. Jake
Got everything tunneled for the drive shaft once I get the driveshaft back from being shortened I can make sure its not hitting anything then I will box back where I cut everything out. Jake
Great build thread!! I am for sure subscribing!!!! Bad***!! Posted using the Full Custom H.A.M.B. App!
